Gear Reduction Starter
Discussion in '1982-Present GM Diesel' started by rustyk5, Sep 15, 2005.
  1. rustyk5
    rustyk5 Registered Member
    Aug 3, 2003
    63
    Hampden, ME
    I want to bolt up one of those before the snow flies up here because my 6.2 doesn't cold start very well. I remember Rene telling me I needed the bracket to bolt it up on my 6.2 block. I can't find one at any of the junkyards around me, and I don't see a listing in GM Parts Direct. Does anyone have a part number or know where I should look. Better yet does any forum member have one for sale? Thanks in advance.
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Go to the dealer, they have them. Only a few $'s
  3. 86dieselburb
    86dieselburb 1/2 ton status
    Oct 20, 2004
    219
    Crestline, CA
    starter hdwe 1989-99 6.2L/6.5L Front Support Bracket 23502557
    You can also make your own out of angle iron. The 6.5 bracket is a straight piece, but the GM part is only a few bucks.
    Look up at the "boatload of part numbers" post. There's a bunch part #'s there.
  4. Robert79K5
    Robert79K5 1/2 ton status
    Mar 23, 2003
    335
    Douglasville Georgia
    Yup I went to the dealer and bought mine for like less than three bucks.
    Got home and took it out of the bag and was like !!!! I could have made that myself in ten minuets out of a piece o angle iron.
    Ah well. If the dealer is on your way home it is nice to have the official factory piece.
  5. rustyk5
    Aug 3, 2003
    63
    Hampden, ME
    Thanks! you guys rock! :bow:
    I love this forum :wink1:
  6. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    what size is that block bolt?
    hey, when you bolt that bracket up...... could you let me know what size bolt goes into the block, mine shook loose and fell off. I just installed the gear reduction starter too (works like a dream). Anyways, i'de like to put my rear support bracket back on for security, just don't know the size. Thanks.
  7. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    if memory serves me correctly the bolt is a M8x1.25
  8. rugger03
    May 14, 2000
    829
    around
    i have never had problems starting my truck in below zero weather without being pluged in, and i had a regular old starter. How old and what type of batteries do you have? have you checked the glow plugs and controller?
  9. rustyk5
    Aug 3, 2003
    63
    Hampden, ME
    I've got ONE optima red top, the bigger one, 960amps I think and Kennedy glow plugs. I personally haven't touched the controller but it looks new. I put a resister on the controller to get about 10 seconds of glow time. My light comes on and everything "clicks" at start up, but I haven't checked each plug with a test light. It just sounds like it isn't rolling fast enough. It never stalls once started and I dont have any air bubbles in my return line every time I check. I did convert to an electric fuel pump, and the starter was rebuilt last fall. I replaced my battery cables with cold crimpped size 0 wire as well. Maybe I'm missing something but I think the starter will solve my issues.
  10. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    Sounds identical to my issues last year and a 6.5 starter did the trick. I reused the original brace by just turning the bolt holes into slots.
    And the bolt head was a 10mm socket so M8 is probably correct.
  11. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Why just one battery? You're asking that one battery to do a lot of work every time you start. I know you can get away with just one, but trust me, doubling your cranking amps with the second battery will make the engine spin over much faster and start easier. However, adding a 6.5L starter will be a great improvement as well.
    If the new starter doesn't help much, I wouldn't go any farther with troubleshooting until you've added the second battery.
    Casey
  12. rustyk5
    Aug 3, 2003
    63
    Hampden, ME
    thanks to everyone with all the help :D
