Gear Removal How to Q?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78Blazer, Mar 18, 2001.
  1. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    I have a jeep dana 44 front that I can not sell so I am gonna remove the gears from it and toss the rest of it. What all do I have to do to be able to take the gears out of it?
    thanks
    Scott
    78blazer
  2. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    Drain the lube,pull the cover,remove the nut and input yoke,pull the axles,remove carrier bearing bolts,pull carrier and ring gear as a unit,remove pinion and gear.
    Putting everything back together is a whole different/difficult story.
    Chuck
    81 Blazer
    <font color=blue>does anyone have another F#@d that I can park on?</font color=blue>[​IMG]
    <font color=red><A target="_blank" HREF=http://www.chucks81k5.coloradok5.com>http://www.chucks81k5.coloradok5.com</A></font color=red>
  3. dyeager535
    26,979
    Loosen the ring gear bolts off while its in the truck..they are likely reverse threads, all the ones I have taken apart so far are, but they are all corporate 7.5" and 8.5" rears. The ring gear bolts are really on there, and no fun to remove from a greasy carrier that has no handles :)
    Dorian
