Gear shifter removel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chrome Moly, Mar 22, 2000.
  1. Chrome Moly
    Chrome Moly Registered Member
    59
    Cheesehead Wisconsin
    I'm droppin the tranny (sm465) in my 88 and was wondering if anyone knows how to remove the stick
    (floor mounted gear shifter). I've got the rubber shift boot and knob off, just need to remove the stick and i'm on my way. Thanks
    Chrome Moly
    <font color=green>Resistance is Futile</font color=green> [​IMG]
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    Post deleted by Chaz88K5
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I did it about 4yrs ago.........
    I think there is a screw out type socket/retainer then push down and to the drivers side......I think.....sorry its been awhile, get a manual I think that's were I got my info to doit.
    Good luck
    And a Stick is way better than a slush box!!
    Burt4x4
    Rock ON!
  4. kim tate
    kim tate 1/2 ton status
    134
    New Orleans
    Did my sm465 last month. Mine is the cover-mounted shift rod, like it sounds you have. After you remove the boot, you'll see a metal cap. Just push down on this cap (I used a piece of 1 1/2 inch PVC pipe slipped around the shift rod) and rotate the shift rod counter-clockwise. The rod is attached similar to how a light bulb (1157 model) is secured to the bulb holder. Hope that makes sense. Oh and be careful, I removed my trans without a trans jack and it is very heavy.
  5. Glenn
    Glenn Registered Member
    87
    North Kingstown, RI/USA
    I happend to weigh my 465. It weighs almost 200 pounds! Oh and its for sale if any body wants it in RI.
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Push down on the cap, but don't try to rotate the shift rod, just rotate the cap CCW. It is easy to do with a pair of channel lock pliers.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  7. Chrome Moly
    59
    Thanks for the insight. Shifter is removed! You guys Rock!
    Chrome Moly
