  1. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    I have been calling in the KC area and asking what a ball park Idea is on a gear swap would run. If i remove the axils myself, and take to one place it will cost me about $600 or if i take it to a differernt shop it will cost me about $1100. Is that to hi? I am going to a 4.56 from a 3.42 in a 10 bolt rear-end. I would rather not remove the Axles myself, my other car is a 2000 accord, dont thing Sara will like me putting then in there. Unless any one in this area has a 12 or 14 bolt with 4.11 or 4.56 that they want to sell me and put on for me. I have the shop man, just never dont any thing that big. Let me know all.
    brettmcox.coloradok5.com
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Too much.
    I can get both axles done for anywhere from 300 - 600 (installation only). Figure another 150 for the gears and install kit.
    89 K5 Silverado
    http://mudfrog.coloradok5.com
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The local 4x4 shop that does gear swaps charged me about $150 in labor to do the front 10-bolt, which is more involved than the rear because you have to pull the hubs and spindles off to get the shafts out, and about another $200 for the gears, setup parts, and all new bearings. I simply dropped off my truck with a box of parts and picked it up later that day.
    I would say that $600 would be a good deal if that price included all labor and parts.......$1,100 sounds way high.
  4. FLWIV440
    FLWIV440 Registered Member
    Nov 21, 2000
    32
    labor should not run more than 600. if it does, try someplace.just did the gears, bearings,and locker in a 12 bolt took 5 hours.
