Gear Weirdness...Help!
Discussion in 'The Garage' started by SchnorrCS, Aug 14, 2006.
  1. SchnorrCS
    SchnorrCS 1/2 ton status
    Oct 11, 2005
    368
    Loveland, CO
    Ok....So I had no idea what gears my truck came with so I had done some math found elswhere on this site and somehow came up with 5:13.
    Just got done taking the cover off to change the 90w and thought I'd count the teeth. 37 ring 9 pinion. Tha6t comes out to 4.11s. Then why the hell does my truck turn 3000 rpms while doing 60? I have 35s on it.
    Also, I thought that 4.11s where a posi gear. As in I though gm only put 4.11s in with a posi rear. Yes? No? Bueller? It's a 74. Dana 44 front, 12 bolt rear. Thanks guys.
  2. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    There was no gear that was exclusive to the Posi, being a 74 it may have been changed by a PO. I got a look at the option sheet for my blazer and 4.11s were an option (its a 73) If you doubt your count somewhere on the ring gear there should be numbers stamped on it. If there is not this is a pretty sure sign that it is an aftermarket gear set.
  3. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,010
    7
    Binghamton NY
    Are you going by the speedo?? Was it corrected for the tires?? If not then you are doing over 60. My old car had 4.10 with 27" tires, and that would do 60 at 3k.
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I got 37s which are only about 36s on the truck and 4.10s with a 700R4 and I can turn 3000 at 60 when I am in 3rd so the numbers work out like yours.
    Ira
  5. SchnorrCS
    Oct 11, 2005
    368
    Loveland, CO
    Thanks guys. There are numbers stamped on it, and they match my count. Why is my truck so damn slow? I know I was doing 60, I checked it with mt gps.
  6. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    Horsepower is horsepower, gears won't make a weak engine a strong one.
  7. b454rat
    Jan 21, 2003
    3,010
    7
    Binghamton NY
    But it will make it feel like you have power!!!!!!
  8. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    True enough. If that's the stock '74 engine, it's rated at either 145 or 160HP (and about 270 ft lbs or torque), tasked to move two tons of steel.
  9. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    and in 1974, wasn't that GROSS horsepower?
    My '74 was a DOG before the 383 upgrade.
    My 3.08 gears still suck though.
  10. SchnorrCS
    Oct 11, 2005
    368
    Loveland, CO
    Motors not stock, but I hear ya. I was just thinking how the hell did people do road trips in the 70s when trucks were topping out at 60-65 mph. I'm getting ready to drive from Cali back to Colorado, and I am going to trailer my K5 behind the pops 1 ton Dodge Dualy, and when he's towing he goes faster than 65, ya know?
  11. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    I think that they'd already started rating net HP back in '72. The mid-late 70s and most of the 80s were dark days, with the automakers scrambling to meet both smog and CAFE mandates while still using carburetors.
    Adoption of EFI helped a lot to meet those dual mandates, while allowing some muscle to return and not blow those other two things out of the water. OD transmissions helped out a lot with mpg when they started showing up on vehicles.
  12. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Not sure what kind of math you did but 37/9 = 4.11
    Like was already said, if you have not recalibrated your speedo after the tire size change then your speedo is incorrect along with the odometer.
  13. SchnorrCS
    Oct 11, 2005
    368
    Loveland, CO
    Uh Yea...I know 37 r and 9 p is 4.11. Already said that. The math I was refering to is an equation for finding gear ratio without knowng exactly what you have. Has to do with speed tie size and rpm.
  14. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Sorry, thought you meant you did the math on the gear tooth and came up with 5.13.
  15. SchnorrCS
    Oct 11, 2005
    368
    Loveland, CO
    its cool
  16. Bullitt427
    Bullitt427 Registered Member
    Apr 22, 2006
    8
    USA
    The RPMs are still fishy Clint...
    If you have 4.11s and 35 inch tires you should be pulling somewhere between 2200-2500 RPMs, not 3 grand.
    What is the actual measured tire height sitting in the driveway? It will probably come out to 33-34 actual height.
    But that still doesn't translate to such a high RPM.
    I assume you are running a manual transmission? If it is an auto with a high stall that would explain the higher RPM, but with a manual, is the clutch slipping? Was 4th gear somehow replaced with an odd gear set?
    I noticed on another post you stated the front axle had a different gear set, so with that logic, who knows what the PO did to that blazer.
    Josh
  17. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Look in his sig he has a 350/350/203, I checked it on www.4lo.com and it works out to 5.13's w/ 35's, 3,000rpm, 1:1 (tranny) and 1:1 (tc) but as stated above it might not be a true 35" tire. My 38.5" MT Baja Claws inflated to road psi are only 37" and even shorter when I deflate for off-road so as stated, go out and measure the tire.
    -Avery
  18. goldwing2000
    goldwing2000 Guest
    Also, you're never going to get a true 1:1 ratio with a TH350. There will always be some TC slippage. Add in a little bit of tachometer error and you could easily have a 500 rpm discrepency.
    To answer the question:
    Easy. The national speed limit was only 55mph and gas was cheap.
  19. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    horsepower wont get a vehicle moving at all, but torque will. gears multiply torque, so they will make the truck quicker out of the hole.
  20. SchnorrCS
    Oct 11, 2005
    368
    Loveland, CO
    Yea, I know it's not a "true" 35, it measures to about 34, but I'm kinda thinking it might have some lower gears somewhere. I thought I read about a "low geared" TH350, but I'll have to do some investigating.
    As far as the axel, another member said something about it being the 1/2" tube, 3/4 ton axle. I think the difference between the gears is just that 4.11 and 4.10 is so close, they may have used them in the factory. Perhaps Dana doesn't/didn't at the time make a 4.11, and since the ratio is so close, GM just said F it.
    Also, with the 1/2" wall tubes, is it possible that my Blazer could fall under the whole "Heavy Half" GM made?
    Josh...You remember my 83? It was a Heavy Half. It was also an 83, and they stopped using the D44 in the Halfs, so maybe that's it.
    Anybody know any web site or something that I could run my VIN or somejunk and figure this crap out?
    Thanks again guys.
    P.S.
    Hey Josh, Shannon said to drop dead....:haha: :D :crazy: :doah:
