Gearin' Question
Discussion in 'The Garage' started by RustyMule, Jan 2, 2005.
  1. RustyMule
    RustyMule Registered Member
    Dec 18, 2004
    73
    Westford, MA
    I was wondering which gears I sould put in my K5 :k5: . It's a 75, 355(ish)/350/203 d44/12 bolt with 35's and a 4" lift. The 'case will be converted to part time and I will be towing a very long distance with it. I could read those gearing charts until I go nutty and still not know as much as somebody who's done it already. I was aiming at 4.56's for the towing and power aspect. Will that be too much gear? I will most likely throw on some 37's when I wear these out so it really is going to be a step beyond a daily driver in the future. I just wanted to throw the question out there and see what people think. Pro's and con's and such. Thanks
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    It would be worth doing a search as this has been covered a lot and again just recently. Many post tell of gear size and cruising RPM that they get.:waytogo:
  3. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    4.10s
    I'd think 4.10s would be good for you with 35s, but towing with 37s I dont know if that'd be low enough for you.
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    For the 35" tires you will want 4.56 gears minimum for towing. With the 37's you will want 4.88 minimum. I'd suggest 4.88 or 5.13's since you plan to go bigger with the tires. If you ever consider going larger than 37's go with the 5.13's the first time.
