Gearing advice needed.
Discussion in 'The Garage' started by broc944, Jan 16, 2006.
  1. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    This is the first time I have posted, so if I am doing something wrong or if I am posting in the wrong area let me know.
    I need advice on gearing my 91 Sub, I am the process of swapping in a 14BFF and a Dana 60. I also have a 203/205 W/PTO, I will be making a Doubler out of. The Sub has a 4l80E, which will stay. Currently running 37" Boggers, will be going to 38" this fall. Front and rear lockers are also going in with the current round of swaps. I also run two full sets of V bar tire chains, in the winter. And yes this truck sees some paved road usage, I like to get out of the woods every so often, but this is not a DD.
    I am at the point of ordering gears and not sure what to do, 4.88 or 5.13 is what I have in mind, and I would like to here what you think. I used to race SCCA, so trucks are something that I need to learn a bit about.
    Hopefully I can add something on here, instead of lurking in the backgound and just reading.
    Thanks, Broc.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    do it right the first time and go with 5:13's:D
  3. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    I would go 5.13s.
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    You probably don't need to go deeper than 4.88 especially if you run on the hwy much, but these guys are right just put 5.13's in and be done
  5. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    5.13's are what I was really leaning towards, I would put
    39.5" Boggers on which would really settle it for me , but my chains will not fit them. I would say my Hwy vs. offroad is 30/70%.
  6. resurrected_jimmy
    May 23, 2005
    2,241
    5.13's cause once you know you have the gearing to handle them the 39.5s will find their way home
  7. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    i see 5.13 in your truck soon.:D
  8. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    5.13's cause you always go bigger on tires...eventually
  9. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I guess that settles it...5:13's :D
