Gearing/axle shaft questions
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Thrashed68, Aug 14, 2001.
  1. Thrashed68
    Thrashed68 Registered Member
    Jul 22, 2001
    8
    Or.
    I just bought a 12 bolt with a Detroit C locker and a front 10 bolt with a lock rite. Both have 4:56 gears. Will this be to much gear for 33 inch tires? Also, the front axle shaft has wallowed out u-joint hole due to a bad joint, Will a D44 shaft swap in directly or due I have to find one from a 10 bolt? And just how weak are these 10 bolts? I am not really into rock crawling or 10 foot deep mud pits, just want good traction for whatever I may incounter. Any opinions are welcome. By the way I only paid 400$ for the axles and they have about 1000 miles on them. Good deal?
    Skin grows back, Parts cost money!
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    4.56 is alot of gear for 33's without a OD! Why don't you make it easer on yourself and run 35's. BTW 3.73 is seams about right for 33's
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  3. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    10 Bolt Axle shafts will not fit in your D44. They have 28splines and not 30 like the D44.
  4. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    The GM corporate 8.5" 10-bolt differential is pretty strong. It's as strong as the Dana 44 and has a stronger pinion shaft, so I wouldn't worry about it as being weaker than a 44. I'm not sure if the axle shafts are stronger or weaker on a front axle, though.
  5. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    The 10 bolt shafts are the same size as the Dana's (not the same shaft but same size). I have 4:10s with 33's I wish I had 4:56 with my 2:1 205 t-case When I'm wheeling. BUT, I can really only cruise around 60-65 on the highway. 3:73 would be a little high off road.
    '70 K-20 San Diego, CA
