gearing for my suburban... got some ???s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, May 6, 2002.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    okay, my suburban is my daily driver so i want some mileage, i get about 8-9/forums/images/icons/tongue.gif in town now and i'm afraid that with 4.56s that'd go WAY down to like 5-6./forums/images/icons/mad.gif so i'm knida thinking about 4.33s. BUT... i have 36" TSLs now and plan on going to 38" TSLs next and then like 42"s, so 36"s are the smallest tire i'll ever run (hopefully). that means i would want to go with like 4.56 or 4.88s but it's still a daily driver. so what do i do?
    does anyone in here run 4.56s and 36" TSLs on their daily driver? what kinda mpg do you get?
    <FORM METHOD=POST ACTION="http://coloradok5.com/forums/dopoll.php"><INPUT TYPE=HIDDEN NAME="pollname" VALUE="1020750938muddysub">
    gearing for the sub
    <INPUT TYPE=RADIO NAME=option VALUE="1">go with 4.56s
    <INPUT TYPE=RADIO NAME=option VALUE="2">go with 4.33s
    <INPUT TYPE=Submit NAME=Submit VALUE="Submit vote" class="buttons"></form>
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I think you need 4.56's /forums/images/icons/wink.gif No but seriously, DesertDueler ran 4.56's on his Jimmy with 35's. He got decent mileage ( i think around 10mpg or better) but his Jimmy was missing hardtop and other stuff so it was lighter then your Burb by a few pounds. Also his truck was freakish, and got like 15 mpg on the highway with a carb. The best I ever got was 13 on the highway with 3.73's &amp; 32's.
    Count your lucky stars, I am going to be running 4.56's &amp; 32's for awhile after my axle swap is complete this summer./forums/images/icons/frown.gif
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    With 4.56's your gas milage goes up around town..Your not smashing on the skinny pedal as hard to get up to speed.Mine went up around town..But got worse on the freeway....Dan
  4. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I'm pretty sure that nobody makes a set of 4.33 gears do they? I have 4.56's with 35''s and they work great, I get 11mpg and that is the same as I got when I had 3.42's with 32''s. What are your gears right now? Sometime when you go to lower gears you will get better mileage because your motor doesn't have to work as hard.
  5. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Scott, I told you you should run 4.56's. The Jimmy has 4.56's with smaller tires than yours and it gets around 9 in town. If you go to 4.33's you won't be better off. You might even get better mileage around town with 4.56's. Anyway, what would you rather have in your heavy ol' 3/4 ton suburban with 36" TSL's? I think 4.56's dude./forums/images/icons/wink.gif
  6. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    I have an '89 1/2 ton with 36's and am running 4.56 gears. I drive to and from work everyday and get about 400 miles on 36 gallons.
    Go with the 4.56 it will work best for you.
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I get 15 mpg on the freeway or in the city. It doesnt matter. I dont know why, but my truck has always go tthe same gas milage. Even when it was all stock with 3.73s and 31s. I am sure the 700r4 helped out on the freeway. But 4.56 gears put you at about the same rpm range as the 3.73 and 31 combo, so go 4.56
    Dan
  8. if you're going to go bigger than 38s i'd go for 4.88s. don't want to have to do two gear swaps. mileage? who dives FS chevs for their mileage?! /forums/images/icons/smile.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What do you have now? 3.73s or 4.10s, I'd think. If you have 4.10s I'd leave them, 2500 or so RPM on the highway is plenty to pull it down the road.
    If you're going to change, go to 4.56 or you'll regret it.
    That said, I've got to run 4.10s and 31s on my C30 without overdrive. It's ROUGH!! 3000 RPM @ 65 sucks.
    But....It gets 13 mpg on the highway. It has a 350 TBI just like yours.
  10. dyeager535
    26,979
    With as tires as large as you are contemplating, I'd say that no matter what gear you put in there, city mileage will not suffer.
    Dads truck, 350 or 454, same truck (4.10 gears) averages the same in the city, freeway is where the mileage difference comes up. Still think about 2500RPM for a stock/mild 350 @60mph is what people should be shooting for.
  11. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    A friend of mine just swapped in axles with 4.88's in his 87 Jimmy. He's running 35" bfg's and luckily has overdrive. He doesnt know what RPM he runs on the freeway, but says it sounds high. I think he still gets around 10 mpg
  12. muddysub
    Jun 23, 2001
    10,451
    489
    i have 3.73s now, i'm thinking about the 4.56s now that i've read all these. thanks! but keep em coming!
  13. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    So you want to have your cake and eat it too ?
    I've got 35's &amp; 4.56's and I'm happy...
    Jim
  14. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    I run 4.56s and 38s. The gearing is nice in town but has absolutely no guts on the freeway. I would say that freeway milage will drop considerably. I keep the pedal to the floor on slight inclines when on the freeway just to maintain my speed. If you can live with going 55-60 itll work for ya but 65 and over is a major strain unless you get some more ponies working for ya.
  15. muddysub
    Jun 23, 2001
    10,451
    489
    yeah, i've got an engine in my backyard ready to be rebuilt now so the ponies will come some day. mudbogad and i are rebuilding it into a 383 stroker and it will probably end up in the suburban.
  16. muddysub
    Jun 23, 2001
    10,451
    489
    thanks a lot guys! i'm going with the 4.56s now /forums/images/icons/smile.gif/forums/images/icons/wink.gif
  17. Mr7dblzero
    Mr7dblzero Registered Member
    Apr 11, 2002
    16
    Aloha. Well next week I will be purchasing a 8" lift all springs and will be getting the 16x16.5x 38 TSL and I was wondering the same ? about what kind of gearing to get. I have a 85 K20 Suburban and was looking at getting at least 4.88 at the least. I also will be using my ride as a daily driver. I also was wodering about locker's. Limited in the front in my Dana44 and Lockers in my 14bolt rear. Dam this is a expensive hobby. but gearing and lockers are going to have to wait 4 awhile until I can save up enough green stamps. When I get pictures I'll send them your way. Aloha From Honolulu Hawaii.
  18. scotty1
    scotty1 1/2 ton status
    Jan 7, 2002
    166
    WV, Harpers Ferry
    The ratios work out for the 35" and 36" at 4:56, this should keep the engine RPMs in the good range for optimum power and mileage.
  19. muddysub
    Jun 23, 2001
    10,451
    489
    with 38"s i'd go with 4.88s. i plan on going to 38s next but i don't know what rim size. i want 15s cuz of the inner safety bead but i already have the 16.5s.
