Gearing...
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Topdown, Dec 15, 2002.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Ok... I finally got the tach installed in topdown. When I bought him the tweak I got him from had a butt-load of extra stuff for the blazer that he "never got around to putting in/on". Needless to say I had to throw 95% of it out, most of it was useless, rusty, or just plain crap.
    Anyway... the point here is that I found 2 sun supertach II's in the pile of refuse that he gave me and told myself "one of these has to work". Wrong. Neither worked. However, when I took them both apart and put the pieces of both together I got one working and finally installed it!!
    Here is the good/bad/question part. The first thing I did was start running some tests to find out what gears I am running. With the 32" tires I run 2000 rpm @ 50 mph... calculated out comes to 3.08 gears. So, when I replace the gearing... should I go with a 3.44 or a 3.73? I use this as a daily driver and do make some long freeway trips in it. I am not going to go any larger than a 33" tire (when my new 32's wear out). Off-road I usually run 4-Hi and dont typically do much rock crawling. Beach/sand is common as are deep ruts and decent amounts of mud and water...
    So... now that I have put everyone to sleep... anyone have any thoughts?
    Thanks!
    -Ryan /forums/images/graemlins/k5.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    IMO, if your planning to eventually go with 33's, I'd go with 3.73's
  3. naranja72
    naranja72 1/2 ton status
    Jan 6, 2002
    110
    vancouver, bc, canada
    here's a link to try out: web page
    hope this helps,
    Marc
  4. Topdown
    Nov 26, 2002
    2,598
    Thank you both for the input... I was leaning toward a set of 3.73's but wasnt sure.
    Thanks!
  5. topjimmy
    topjimmy Registered Member
    Feb 20, 2003
    9
    Glen Burnie, MD
    Hey, i'm planning a gear swap as well...i was leaning toward 4.10's. i have 35's, don't do serious wheelin'...the chart just confirmed my choice...THX!!! /forums/images/graemlins/cool.gif <font color="blue"> </font> /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  6. Topdown
    Nov 26, 2002
    2,598
    after much debate and thought, I believe I will be going with the 4.10's (can someone tell me the real difference between a 4.10 &amp; 4.11? I see them both used regularly)
    Thanks for all your help everyone!
  7. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Ryan,
    I wouldn't trust the tach to help you determine your axle gears!! ......you aren't doing that are you?
    HEI and AT tranny slippage can make the numbers less than accurate when comparing a chart of RPMs to actual measured RPMs
    You should really be safe and pull one of the diff covers and look at the ring stamping to get the correct tooth counts so you know FOR SURE that you have 3.08s or whatever....
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    different tooth count on the gears, 4.11 typically seen in gm corp 12 bolts and 4.10 typically seen in 3/4 and 1 ton eaton/gm corp axles
    same deal with 3.07 vs. 3.08 ratios- 3.07 usually only seen in the 8.5" 10 bolts and 3.08 usually seen in the 7.5" 10 bolts, tooth count on gears differ between the two ratios
  9. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    A 4.10:1 ring and pinion setup will have 41 ring gear teeth and 10 pinion gear teeth. A 4.11:1 setup will have 37 ring gear teeth and 9 pinion gear teeth (technically, 4.1111...:1). The gear you'll find in the 12-bolt truck rear would be a 41:10 setup. Most aftermarket suppliers also make 41:10 setups in lieu of 37:9 setups.
  10. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    stock gearing on early 5k's was 3.73:1 wasnt it?i always thought thats what all first gens had.i've had 3 different 12 bolts from 72 blazers.and they all had 3.73 gearing.
  11. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    most likely if your running stock you probably have 3.08's in that 10/12 combo.
  12. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    In a first gen it's a Dana 44 and a 12 bolt, not a 10 and my stock geras were 3.73 (with a 307ci and TH350)
  13. Steve_Chin
    Mar 6, 2001
    1,126
    chulisohombre, it depends on the original engine configuration. 350 trucks got 3.07:1 axle setups as base (3.73:1 optional). 307 trucks got 3.73:1 axle setups as base. GM deemed the switch to 3.07:1 for the 350 as acceptable because of the additional torque the 350 has over the 307 (and, in doing so, they raised the CAFE ever so slightly).
