gearing ?????
Discussion in 'The Garage' started by dheavychevy38, Jan 25, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    I have a 1987 gmc 36 ground hawgs a 465 with a 208 a built 6.2 diesel 4.11 rear ends and i want a gear to be more for highway use cause it winds out to easy and i drive it to mexico from il any ideas???? /forums/images/graemlins/crewcab.gif
  2. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    Check out www.4lo.com. There's a great gear calculator on there that will tell you engine rpm, mph, etc. in relation to the tire and axle gear ratio you choose.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i would keep those gears but if you want better freeway gears go with 3:73's
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Because you have the diesel I would reccomend probably either 3.42s or 3.73s. 3.42s would keep you rpms down, but if you motor doesnt have alot of power it will be real slow off the line.
    Dan /forums/images/graemlins/burb.gif
