  1. blazerboy5814
    blazerboy5814 Registered Member
    May 12, 2003
    10
    I recently bought a 88 K5 blazer its bone stock except a flowmast muffler that was installed by the previous owner. It has 33x12.5x15 tires and I was wondering if i need to change the diff gears or if i'll be allright like this. /forums/images/graemlins/k5.gif <font color="black"> </font>
    A lift is on its way.
  2. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    well, got to know what your gears are now,an if you do need to change gears just get whole new 3/4 ton axles much cheaper than new gears and extra strength /forums/images/graemlins/thumb.gif
  3. blazerboy5814
    May 12, 2003
    10
    Ok its the stock ratio it had 31 inch tires stock
    but i can't find out what it is imagine about 4.11 <font color="black"> </font>
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> So what you're saying is, you don't know what gears you have and you can't find out, but you want to know if you should change them. Ummmmmm, maybe. /forums/images/graemlins/rolleyes.gif
    BTW, if it has 4.11s it would be pretty rare, they didn't come in many 1/2 tons from the factory, and those that had them usually had 6 cylinder engines.
    Perhaps a better question would be "How can I find out what gears are in this Blazer I just bought? /forums/images/graemlins/thumb.gif </font>
  5. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    go here:
    http://www.angelfire.com/ny2/96transam/rpocodes.html
    look up the code (located inside your glovebox door). Find the code on that website, and if your rearend is still stock, it will tell you what gearing it has. (should start with a "G" or an "H")
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    you could always just jack it up and see how many times the driveshaft turns for 1 revolution of the tire! /forums/images/graemlins/thumb.gif
  7. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Open the glove box and look for the the paper with the options if theres not one there look on the driverside innerfender, but rember they COULD have been changed BTW if its stock its probably 3.08 or 3.42 MABE 3.73
  8. blazerboy5814
    May 12, 2003
    10
    Its 3.42. Is this fine? Tell me what you guys think.
  9. chev4life
    chev4life 1/2 ton status
    Jun 21, 2001
    416
    San Jose, CA
    That is exactly the setup that I am running and it deffinetly lost its get up and go. I also have a prob going the speed limit with the setup cause the tranny doesnt like using OD till over 70 now. I deff want to do a gear swap also, but was wondering the same thing...is it better and cheaper to go with an entire new axle assembly? If so where do you find those and what gears coem in them?
  10. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I've heard that junkyards sometimes have axles... /forums/images/graemlins/tongue.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/wink.gif
  11. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    For 33's, I would recommend 4.10's. This would keep you from having to mess with speedo stuff, but will give you better "get up and go".
    Doing this is relatively cheaper than going to 3/4 ton axles. You have to think of what else you will have to spend to get you where you are at right now. If you are considering a locker, then yes, but otherwise stick with your current setup.
    /forums/images/graemlins/burb.gif
  12. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I usually wait until the brakes are shot before swapping axles - makes things more cost effective /forums/images/graemlins/grin.gif
    A 14-bolt fullfloater can be had in the $100-200 range - most have 3.73 or 4.10 ratios. For the front, you can go three ways:
    1. re-gear and add 8-lug hubs/brakes.
    2. replace entire front axle (perhaps from same truck as 14-bolt comes from)
    3. Dana 60 front axle (can be costly ~$1000 range)
  13. bigjbear
    Feb 18, 2000
    13,966
    447
    Marietta GA
    [/ QUOTE ] W/ overdrive, that would be perfect... for a 26" tall tire. I would go w/ 4.56:1 if you are keeping the 33s.
