gears and carrier
Discussion in 'The Garage' started by 88GLAZER, Mar 24, 2004.
  1. 88GLAZER
    88GLAZER 1/2 ton status
    Nov 19, 2002
    111
    West Virginia
    I have 3.42 gears in my 14 bolt FF, if I want to go to 4:56 and up do I need a different carrier.
  2. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    yep you do unless you get thick gears. The break is 4.10 and down numericly and 4.56 and up numericly.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    You've actually got the ideal carrier to do this.
    What you need to buy is 4.56 THICK gears (as stated above). Odd thing is, these seem to be more plentiful than the "regular" 4.56 gears. /forums/images/graemlins/crazy.gif
  4. 88GLAZER
    Nov 19, 2002
    111
    West Virginia
    are the thick gears stronger?
  5. heavy4x4
    Aug 28, 2002
    3,270
    Not really...the ring gear is thicker to make up the difference between the two carriers. But ring gears don't usually break in half, the teeth shear off, and there's no difference in the teeth between the thick and regular ring gears.
