gears and lockers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bUrLyBlAzEr89, Jul 17, 2002.
  1. bUrLyBlAzEr89
    bUrLyBlAzEr89 Registered Member
    Jul 10, 2002
    47
    Nipomo, Ca
    when i bought my blazer, it came with detriot lockers and the differ. covers have AG (american gears) does that mean they changed the gears also or how can i test and find out?
  2. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    They might of hard to tell though. If it is omething like 3.08 in a 1/2 ton i doubt they changed it though.
  3. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Kinda pointless to drop the money on a detroit locker and not gears first, if it is real doggy power wise then you probably have 3.08, if you can bark the tires on a straight takeoff then you might have 3.73, if you can flat out spin them then its probably 4.10 or even 4.56 /forums/images/icons/grin.gif
  4. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    If it has lockers and they changed the gears I would think they'd go with lower gears. The rotate the tires and count the drive shaft metod will give you an idea of the ratio. You can also pull the covers and see if the ring gears are stamped.
