Gears and springs
Discussion in 'The Garage' started by Mr. Jimmy, Oct 6, 2002.
  1. Mr. Jimmy
    Mr. Jimmy Registered Member
    Mar 14, 2002
    63
    Haynesville Ga.
    Can anybody tell me what the gear ratio is for a stock 77 Chev. 4WD truck running a T-350? I'm thinking about swapping my 89 Jimmy 10 bolt 4.56 and 6 in. lift for a 12 bolt and 4 in lift,are these springs and rear ends compatible with out any mods? Will also be swapping frt ends as well.I have measured the length of both trucks rear springs and they measure 52 in. from eye to eye.
  2. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    gear ratio codes ok in yer glovebox there should be codes on a paper. that link i gave you is the codes for what ring and pinion you have. hope this helps. btw i did a search and i found it real quick. the search button helps out alot. later.
    jacob
