Gears, anyone?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fbronson, Feb 25, 2004.
  1. fbronson
    fbronson 1/2 ton status
    Jan 12, 2004
    104
    Denver, CO
    My '83 K5 and I are both new to the world of modifications, and I have a question concerning finding the right gear ratios for the axles. Recently, I installed a 4" lift and 33X12.50's. Everything else in the driveline is stock... this translates to 6.2L, 700R4, and GM 10 bolt axles, front and rear. I've already decided that the next time I buy tires, they'll be 35's. So what is the best ratio for the axles, 3.73, 4.10? Also, I have heard about the 10 bolt being a little on the weak side. In replacing the oil seals in the rear axle it occured to me that if the axle shaft broke, there would be nothing to prevent the broken shaft and wheel from just sliding right out of the axle. Is it worth my time and money to find some beefier axles? /forums/images/graemlins/ears.gif
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Here is the best gear calculator I have seen, plug in the #'s and you can see what you need to do.
    Gear Calculator
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    yes
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Either 4.10's or 3.73s with a diesel, 35's, and 700R4 would be about right. 4.56's and you get to many RPM. I think that 3.73's would be better for the RPM's if you want to cruise at 75 and need to kickdown.
    Harley
  5. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Yes 10 bolts are weak! You want 14BFF & D60 setup /forums/images/graemlins/peace.gif!
    Bill
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    FF14B suck w/ 35s if you plan on wheeling & a D60 is overkill w/ 35s. What are you plans for this truck? Give us your plans and we can give you a better answer.
  7. fbronson
    Jan 12, 2004
    104
    Denver, CO
    Here's what I plan on in the forseeable future. Not too much more on the driveline besides the 35's, and the existing 4" lift. I would really like to get rid of the stock GM style steering drag link, and put on a link that is parallel to the axle, and connects to the passenger side knuckle. This will facilitate losing the sway bar as well. A rear disc brake conversion looks like it could be extremely useful as well. Other stuff will include bumpers, rollcage, winch, etc... Of course, as time and trails go by, I'll probably end up doing more /forums/images/graemlins/thumb.gif
  8. jakesdad
    jakesdad Registered Member
    Feb 17, 2004
    7
    Howell, Michigan
    FYI, I'm running 4.10s in my 91 Sub with 35's and 408/4L60/10 bolts. The over-all gearing ends up being close to when it had 31's and 3.42 gears (stock). The speedo is almost dead on. If you tow, you might want the 4.56's. I'm considering the switch. Just my opinion.
  9. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    something isnt working out right for me with that gear thing.
    when i pick the 700r4/241/4.10 combo its saying 4328 rpms at 66 mph with 40" tires.
    am i keying something in wrong?
  10. jakesdad
    Feb 17, 2004
    7
    Howell, Michigan
    I got the same thing. Looks like you have to take the t-case low value out, then it works. You got the rpm at that speed in 4-Lo.
  11. fbronson
    Jan 12, 2004
    104
    Denver, CO
    I just checked out the gear calculator. That is a really cool page! It does list the T-case high values even if you leave the low range in there, you just have to scroll down past 4th gear T-case low. How is towing with the 4.10's. Do you think that the extra weight of the 'burb makes a difference, i.e. would I be able to get away with pulling something up a hill with the 4.10's? Also, for anyone who has some experience, if I plan on some mild rock crawling, am I going to seriously risk breaking those 10 bolt axles? /forums/images/graemlins/ears.gif
  12. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    10Bs hold up ok to 35s if they are properly maintained. If I was starting over knowing what I know now I would have used a D60 in the rear. Or if i couldn't find one for a good price (which is unlikly because there are tons of them out there, more than the FF14B) I would have used a SF14B. I like the 60 better though because of the FF shafts. Another option (more expensive, though) would be the rear out of a late model F150, 9.75 R&P and IIRC disc brakes. D44/10B fronts do fine w/ 35s, keep good u-joints in the shafts and if you add a locker add better shafts as well.
