Gears...carrier torque specs?
Discussion in 'The Garage' started by broncoman6524, Jan 13, 2007.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    ok 10b rear...I was replacing the axle shaft seal and pinion seals today in the "new" axle. i pulled the center sect to remove the pinion, come to find out one of the bearings is toast. anyway what do i torque the caps down to? 80right?
    i *believe* that ive set up my pinion correct again, same #of threads and it is close (1-2lbs) from the torque to spin it from wheni pulled it apart. did i do that correct of did i just **** up the whole thing?:haha: :doah:
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The torque required to move the pinion is measured in inch lbs. not foot lbs. A new crush sleeve is required anytime you remove the pinion nut as well as a new pinion nut. The carrier cap bolts torque is 55-60 ft. lbs. The pinion bearing preload is 5-15 inch lbs for used bearings and 20-25 inch lbs. for new bearings.
  3. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    preload is just like rotating the pinion w/o the ring gear installed correct? thanks man i REALY appreciate it
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    That would be correct.
  5. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    gotcha...to get it to around 8ish (orig before new seal) i would just tighten the nut on top of the pinion correct? and the new seal i read somewhere adds 3lbs resistance so i should adjust to 12inchlbs?
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The last i remember you are suppose to set preload without the seal installed, but that contradicts the whole theory os having to change the crush sleeve everytime you remove the yoke. Did you install new bearings and a crush sleeve?
  7. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    no the bearing felt/looks fine so im not gonna replace it...i didnt replace hte crush seal either. but since i gotta put a new one in everytime i gotta pick one up when i go to advance tomorrow to get the new bearing as well.
  8. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    when you tighten down the pinion nut it should take about 25 in/lbs to turn the pinion
  9. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
