Gears & Diesel
Discussion in 'The Garage' started by zap275, Mar 25, 2004.
  1. zap275
    zap275 Registered Member
    Dec 8, 2002
    22
    Florida
    My rear axle gave way and looking to rebuild. I have a 6.2 diesel with 700 OD Tranny. I have 35 inch tires. I do not want to sacrifice fuel mileage. I have been told 4.10 gears with a detroit locker will work well with 10inch rear. I would appreciate any help and input. I am looking at spending almost 1000.00 dollars for new gears front and back with bearing kits and detroit locker. I do not want to wind my diesel out on the interstate. Thanks /forums/images/graemlins/k5.gif
  2. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    Round about way of answering your question...
    To figure engine speed:
    (MPH x drive ratio x 336) / Tire Diameter = RPM
    Example:
    4.10 is the axle ratio; 0.69 is OD ratio; your drive ratio is 2.829. Sooo...
    (65 x 2.829 x 336) / 35
    becomes
    61785.36 / 35
    So your engine RPM is 1765ish. Room enough to spare a little faster than 65.
    Though with 35s you might want to be looking for a 14bff instead of a 10 bolt /forums/images/graemlins/dunno.gif
  3. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Yeah you can find a 14BFF with 4.10's for $200 or less, and a Detroit for a 14BFF is as cheap as detroits get
  4. zap275
    Dec 8, 2002
    22
    Florida
    Thank you for your input. I have been shopping around and I am able to have driveshaftspecialist.com build a rear end 10 bolt with eaton posi and 3.73 gears complete ready to install for under 1600.00 dollars. I do not do alot of 4 wheeling mostly road traffic. I think the "14" might be too stout of a rear axle for my truck. How is that set up that i'm considering? I also heard detroit lockers are locked whenever put under a load from the engine.
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    You cant really have too stout of an axle only prob is the FF is 8 lug, but that can be converted. A 14FF w/ 4.10's for 200, and a detroit for either 3 or 4 hundred, still 1k cheaper than a 10bolt, alot stronger too. And it should be pretty much ready to bolt in. And yes the detroit is locked when under power. So if on the gas around a sharp turn you will chirp the inside tire. Let off the gas, it will unlock and it will be pretty much normal.
  6. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Don't waist the $ on the 10 bolt, you will regret it in the future.
  7. landcrusher
    landcrusher Registered Member
    Jan 21, 2004
    33
    Escondido, CA
    $1600 for a 10b... no way.
    Spend the same cash (or less) and get the 14bFF! /forums/images/graemlins/waytogo.gif
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    $1600 for a rear 10-bolt /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
    I'd go to a junkyard and buy a 3.73 factory geared 10-bolt for $100-$200 WAY before I'd even think about spending that much on a rebuilt rear axle.
    For the gears, my K5 with a 6.2/700r4 combo came with 3.73 gears and tiny 235/75R15 tires stock. I ran the 3.73 gears with 32's and 33's and it seemed to be okay, I then switched to 4.10's with the 33's and it worked pretty good (couldn't really notice that much of a difference between the 3.73 and 4.10 gears though). I later switched to 35's and it was pushing the 4.10's a little. So basically I would suggest at least 4.10's for 35" tires if you did mostly freeway type driving.
  9. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Dangit, I will sell you my 3.73 geared 12b for $1600, with ANY locker/limited slip you choose....
    For $500 more, I will even paint it for you, your choice of colors /forums/images/graemlins/waytogo.gif
    /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  10. elacruze
    elacruze 1/2 ton status
    Dec 23, 2003
    121
    SE Michigan
    My '85 6.2 with TH400 and 4.10 gears, 235-85 tires gets 16.5 mpg on the highway. With 35's and overdrive, I'd say that 4.10s are the way to go, but definitely not in a 10 bolt. The 700r4 has a much lower first gear, and with the bigger tires and diesel you'll just kill the axle again. Get a 12 bolt at least, or have those $1600 thieves build you a 6 lug 14 bolt.
    My $.02
    Eric
