Gears for a family diesel
Discussion in 'The Garage' started by big_truxx, Apr 16, 2005.
What gears would be best for milage in a family burb w/ 6.2 and a TH700?
  1. 3.08's
    14.3%
  2. 3.42's
    50.0%
  3. 3.73's
    35.7%
  4. something else not listed
    0 vote(s)
    0.0%
  1. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    As the title says gears for a family grocerie getting burb :D
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I believe 3.08 was only offered in the diesel Burb for the first few years. 3.42/3.73 are the other possibilities.
    Most 3/4-tons have 4.10 gears and a TH400 (not OD). They're okay for city driving, but suffer on the highway. I swapped a 3.21 axle into mine for this reason.
    IMO, look for a '91 3/4-ton. You avoid the fragile 10-bolt and small 1/2-ton brakes, and get a 4L80E (OD trans).
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Keep in mind that if you are going to run a 700R4 even with the low stall deisel converter that you need to try and keep the RPM's up a little bit so you don't lug the motor in OD and put extra heat in the tranny.
    I would say run 3.42's or 3.73's and a big cooler. This is especially true if you are going to up the tire size over stock any or are going to tow any.
    Harley
  4. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    3.73... ford chevy and dodge all use 3.73s standard in their new diesel trucks. other ratios are optional.
  5. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    That is a cool fact to know :D :waytogo: I am still thinking for milage reasons if and when I get a diesel to go w/ a set of 3.42's for better milage. But I will most likely not be getting this rig soon. I have a garage and a house w/ all the things that go with it like septic system, driveway, well etc etc to work on currently. So my 82 dd will most likely be the only vehicle I own for a bit (after I sell my other 2 trucks and the jetta anyway) But when I do get t the point of locating a diesel burb, then it would be for road use only going places and not hauling anything save for family (when I am fortunate enough to have one) and groceries. :D
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    my 83 came with 3.42 gears... Cruises down the highway great. :)
