Gears? I did a search.
Discussion in 'The Garage' started by RingMaster4x4, Jul 9, 2003.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I read Zakk's post about 5.13's but still not sure. I run about 2500 RPMs going down the highway right now, with Blazer in my sig. The tires are really 41" tall. I have a TH350/NP205. So I am turning to everyone here for their options. Thanks for your time.
    P.S. I do drive this daily and I make 200 miles round trips on the weekends.
    <FORM METHOD=POST ACTION="http://coloradok5.com/forums/dopoll.php"><INPUT TYPE=HIDDEN NAME="pollname" VALUE="1057774781RingMaster4x4">
    Gears?
    <input type="radio" name="option" value="1" />4.56
    <input type="radio" name="option" value="2" />4.88
    <input type="radio" name="option" value="3" />5.13
    <INPUT TYPE=Submit NAME=Submit VALUE="Submit vote" class="buttons"></form>
  2. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    if you want to check the rpm's, you can go to 4lo.com and check it out
  3. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I have checked that but I would like some input from other people.
  4. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i run 5.13's w/ 42's &amp; otherwise the same set up. mine is not a daily driver but i don't notice excessive rpm's at highway speeds. /forums/images/graemlins/thumb.gif
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    you know what I voted for! /forums/images/graemlins/thumb.gif
    I turn about 3200 RPM's at 65 MPH. I'm running tiny, little 40's so your 44's will do much better Plus, with the added weight of your rolling assembly (IIRC, 44" TSL's weight ~115# each...without a rim!) the 5.13s will give you more mechanical advantage to get them moving. and a BBC won't hurt either!
    I've only got a little SBC 350 that pumps out maaaaaaaaaaaybe 250 HP and the 5.13's are still good. I just need to get my overheating problems in line /forums/images/graemlins/crazy.gif
  6. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Come on. There has been 42 people look at this post and only 5 Vote. /forums/images/graemlins/1zhelp.gif
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    not to be rude, but your running 44's. 5.13's are about your only choice, unless you want to swap to a D70 rear and run 5.86's.
    my post about 5.13 were directed to the 700R crowd with 35-37" tires. with a TH350 and 44's, you need all the help you can get to move those tires and not burn up your tranny.
  8. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    So the gear change should not make my big block turn to many RPM's.
  9. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    That is my last question and I will drop it. Thanks. /forums/images/graemlins/thumb.gif
    P.S. It is stock.
  10. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    randy's gear calculator says you'll be at 2700 RPM's at 65 MPH
    but you didn't drop in a big block and add 44" tires for their gas savings!
  11. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    OK I am done. Thanks for everyones help! /forums/images/graemlins/thumb.gif
    What are you talking about I get great gas milage. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
