Gears in a 14bolt
Discussion in 'The Garage' started by petryshyn, Nov 17, 2004.
  1. petryshyn
    petryshyn 1/2 ton status
    Jun 6, 2004
    150
    Yorkton,Sk
    I am just wondering what stock gears come in a 14 bolt axel, front a rear, and how hard would it be to swap it onto my 86 blazer.
    Great site, just setting up my paypal to get a membership
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    14 bolts are for the rear and gear ratio depends on what it comes out of. My van width came with 3.73 where most 3/4 tons and 1 tons came with either 4.11 or 4.56 gear ratios. Not sure about doing the swap, I have a set of gears and carrier from another 14 bolt that I will be taking to a shop and have them install for me.
    James
  3. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Sorry about that, I thought about swapping gears. The swap of the axle is pretty simple, all you need is new ubolts and a conversion u joint for your drive shaft and voila, it is underneath you truck. Some years of the 14 bolts have different e-brake styles so watch out when you are purchasing them. Try to get one that will bolt right up to yor e-brake lines unles your planning to run rear disc brakes then whatever you want will work.
    I chose the van width axle due to it is 3" wider and will keep me from running spacers on the rear so I can have the same front/rear track width.
    James
