gears or engine
Discussion in 'The Garage' started by bedford, Jun 20, 2003.
  1. bedford
    bedford Registered Member
    Feb 17, 2003
    9
    Fort Worth, Texas
    I bought a 86 back in feb. and its real slugish it has a 305 and 3.08 gears with 35" tires
    If I change the gears do you thank this will help my power problem or do I need to change the
    motor out first. /forums/images/graemlins/1zhelp.gif
  2. MousePowrd
    MousePowrd 1/2 ton status
    May 7, 2003
    215
    Saginaw, MI
    Change the gears first, they have to be changed anyways.
    3.08 and 35's must really suck. Even with a 383 you would want 4.10's probably
  3. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Yea I figure 3.08 and 35's with a 305 must be really doggy. But what do you plan do to with the truck? It will probably be cheaper to get a set of 3/4ton axles then to change the gears If you plan on doing anything rough you really should get somthing stronger then ½ton SO I say go for gears(or axles with gears all 14bolt FF's have atleast 3.73 but most have 4.10) then a 350 swap then build the 350. /forums/images/graemlins/thumb.gif
  4. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    GEARS, at least 4.56.
  5. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
