Gears or intake and cam
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, May 29, 2002.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    What would you guys do? I run 33/1250 tires with 3.07 gears and a stock 350 engine that runs great. I am trying to decide if i should do a cam and intake swap or change to 3.73 gears. What do you think would give me the most difference in power, I don't have money to do both at this time, what would you do first?
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    change to 3.73s. i think seventy4blazer has the D44/12Bolt set.
    ARQ.
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Gears.
    Making more power won't help if the motor is lugging...
    Rene
  4. bajaviking
    Apr 10, 2002
    752
    Baja
    Is 3.73 a good ratio for 33 inch tires, this is my daily driver also. I have a 700 tranny with overdrive.
  5. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    if you have the over drive, you could go with 4.11s. IMO i would go 3.73s with 33s
    ARQ.
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    With overdrive you can go deeper...4.10's or even 4.56's. 4.56's, 33's you'd be turning 2300 RPM at 70 on the freeway.
    The 700R-4 will love you for the deeper gears...
    Also with 4.56's you could step up to 35's one day without worry.
    Rene
  7. dyeager535
    26,982
    191
    I'm with Rene on the gear choices...if 4.56's put you in the low 2000's RPM wise at 70, then go for them. You *might* be ok with 4.10's, but as I've found on my (apparently stock) 350, 2300RPM is this motors cruising "sweet spot" and I can pull 70mph up any grade at that RPM....not to mention, the acceleration for passing is pretty darn good too.
    Definitely in your case gears before cam/intake though.
  8. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I smell a re-gear cookin...
    Jim
  9. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I have currently 33's,700r4,3.73 gears...I like it. But when I add my 4" springs and go to 35's I should be ok untill I get some cash and change the gears yet agian!
  10. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Gears!! Not 3.73's!! If you are keeping 33's, get some 4.11's, if you plan on EVER stepping up, 4.56's are nice. I run 4.56's with the 700R4 and 35''s and love it, no lugging of the motor, and it can still keep up with traffic on L.A. freeways. I would say that 4.56's would be a bit much for a 33'' even with OD, but you would be happier with 4.11's than 3.73's.
  11. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Just mentioning something that no one esle has.
    What about a set of 3/4 ton axles with 4.10 or 4.56s already
    in them. A step up in strength and would end up beoign about the same price overall.
    Ken H.
  12. bajaviking
    Apr 10, 2002
    752
    Baja
    As Jim said, I smell a re-gear cooking. After reading your posts I think i will go for the 4.10's. I was thinking about the axle swap but I just put a lockright in my rear diff. and I only have to pay for the gears( my mechanic friend will install them for me) so until I break my lockright I think I will stay with the old setup.
  13. aandpman
    aandpman 1/2 ton status Premium Member
    Sep 6, 2001
    151
    7
    Austin, Texas
    So get a 14bff rear and toss the lockright upfront in yur 10-bolt.....Hey - its a thought..../forums/images/icons/crazy.gif
  14. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    cam and intake. marv springer runs 35's with 3.73. he has a doubler for the trail. i am sure you will end up doing both in the end but i would go with intake and cam first. it will cost less if you do the work yourself.
    grant
  15. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    oh, and yes, i do have a set i would sell for a 12 bolt and D44.
    and my room mate has a set of 4.10 he might part with
    pm me if interested
    grant
  16. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    OK, I'm going to be the oddball. You will notice a big difference if you do some motor work. A strong 350 will pull 33"s with 3.07's all day and not break a sweat.
    Probably should do a ring job too while you're at it. Sure brought my old hoss back to life!
  17. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    Gears Gears Gears. You've got a 700, so 4.56's are like running 3.20s with a TH350 .. You have to try hard to over-rev a 350 with 3.07 gears in it. Plus, with the added weight of the wheels and tires a little mechanical advantage at the tires and a few more rpm from a standstill will help. By far my 4.56 gears are the best all around mod for running bigger tires, wish I'd done it sooner.
  18. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    i have 4.11's and 33's and love them in the city...on the highway, I wish I had 3.73's though. I'm gonna be driving this thing to college next year - a 6 hour drive - and wish I had done 3.73's...if no highway, go 4.11's
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  20. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Gears is the way to go. I ran 3.73s and 32s for years, but they wouldn't cut it when I stepped up to 35s. Installing the 4.56s was the best thing I have ever done on my rig.
    Having a friend install them is going to save you mega-bucks. But, watch, help, and learn. It will be invaluable to you. i would also agree with the axle swap. If you have the time and money associated with a swap, then put in a 14BFF rear and put your lockright in your front 10-bolt. However, I know this costs a lot more than just the axle. You will have driveshaft and u-joint concerns. You will also have to either convert the front to 8-lug or have to deal with 2 spares. You will also have to get new wheels with 8-lugs.
    So, if all that is too much to take on right now, just go with the gears. Watch and learn so you will know how to set them up. Then, at a later date, you could always swap in a 14BFF and install matching gears yourself (if it didn't have the right gears already).
    I know 4.56s are overkill for 33s even with a 700. But, you will go bigger. We all do! And then you will really be pleased with the 4.56s. Just saving you some time and money in the long run.
