Gears stock Blazer k5 1987
Discussion in 'The Garage' started by keevy, Dec 27, 2004.
  1. keevy
    keevy Registered Member
    Aug 24, 2003
    36
    Belgium
    What gears have a stock Blazer k5 1987 10 bolt
  2. tRustyK5
    Jul 23, 2000
    36,188
    1,394
    E-town baby!
    Pretty hard to say for certain without pulling the diff cover off. There were many common ratios, from 2.73, 3.08, 3,42, and 3.73.
    The glove box should have some three letter codes that may be accurate if the diff's have never been changed. look for GT5 or something similar. Probably find G80 in the list too. G80 is the code for a Gov-Lock.
    Rene
  3. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    you forgot 3.53 's
  4. dyeager535
    26,982
    191
    I'd like to see an RPO in a later K5 with 3.53's. Never heard of that. Rene's numbers are right as far as I know, although I believe the 2.73's were dropped in the early 80's.
    The Blazer brochures available for browsing online will tell what was or was not available, but I believe (without checking) it was 3.08, 3.42, and 3.73 only, in the K5's by about 1985.
  5. BrianDamage
    May 14, 2001
    753
    Alabama
    my bad
    for some reason, I always mix up 3.42 and 3.53 (my 87 is 3.42)
    I don't know why
    I'm a retard
    I shall retire to my cave
  6. tRustyK5
    Jul 23, 2000
    36,188
    1,394
    E-town baby!
    Happens to the best of us...don't sweat it.
    Dorian, thanks for the scoop on that. I wasn't sure if and when the 2.73's were dropped...
    Rene
  7. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    my 84 don't have the codes on the glove box door is there some where else. I've been meaning to figuar out the ratio's just haven't got to it and would love to find a easy way like a three letter code to get them
  8. tRustyK5
    Jul 23, 2000
    36,188
    1,394
    E-town baby!
    Without the code the only way you'll know is to pull the covers and look for the codes. It's a good excuse to do a service anyways.
    On the edge of the ring gear you should find a series of numbers. The first group will be a part number that won't tell you much. there will be a space, then two number another space, two more numbers etc etc.
    Might look like this: xxxxxxxxxxx 11 41 10 86
    The last two numbers are the build date, in this example the build date would be Oct 1986. The previous numbers refer to tooth count on the pinion gear and the ring gear. In this example it would bee 11 pinion teeth and 41 ring gear teeth. If you do the math my exaple diff would have 3.73's and was built in oct 86.
    HTH
    Rene
  9. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    I think I'll do it the lazy way in a coulpe days, put a mark on the tires and a mark on the yoke and move the truck forward with help of coarse so I don't get run over I HOPE! and count the roatations the yoke makes.
