Gears with 38.5" tires?
Discussion in '1982-Present GM Diesel' started by smprider112, Jun 17, 2004.
  1. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    Gears with 38.5\" tires?
    I currently have 3.42 with 35x15.5x15 swampers....and my truck is a TURD!! its descent for town but if there is a hill it hates it! so Im thinking bout 4.10's BUT now I may wanna get 38's later down the road....will these gears be adaquate for this?? or should I possibly go to 4.56's? I'd hate to change out my gears then later get bigger tires and be back where i am now. Anybody running this combo with a 6.2? I need advise! /forums/images/graemlins/dunno.gif
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Re: Gears with 38.5\" tires?
    I am running 4.88's with 39.5 boggers , wish I went with 5.13's
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I run 4.56's with my 39.5" TSL's and I like it just fine. Could use overdrive for the freeway though.
    Rene
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    What transmission do you have?????
    I have 4.10's with 38" Swampers and in Drive it cruises pretty nice on the highway, but you cannot use O/D on the 700r4 because of the lack of power.......wish I had 5.13s
  5. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    Are you wanting beter running than stock?
    Eddie
  6. mcinfantry
    mcinfantry 1/2 ton status
    Dec 2, 2003
    308
    4.56 38.7 michelins and nv4500. im happy
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i've got 4.56s and am going to run a 38.5-39.5 tire.
    ltalessi, what kind of Michelins do you run?
  8. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Not to hijack, but i have the 3.42 gears and plan on running 35x12.5 or 14.5 inch tires, rite now i have 33x12.5s and its turning about 2500 rpms at about 55 mphs, and i was wondering if it will be ok to run the 35s and not be sluggish up hills? It has a th350 that was built to handle 35s and about 500 hp do u think that will off set the gears in the axles a little bit so its not so sluggish? Sorry again to hijack, just wondering.
    Cory.
  9. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    but i dont have the deseil motor any more either.. i have a sbc 400..
  10. mcinfantry
    Dec 2, 2003
    308
    im running michelin 1100x16 xl's
    id like to add i do fine on highway with 105hp at 2300rpm and 286ftlbs torque at 1600rpm. the truck is no speed demon, but gets out of its own way. i get 22mpg in the city, 24 on the highway at 70. i SHOULD get 30mpg at a constant 55mph to 60mph.
    i just got back from LBL Ky and ran all the trails in 4wd lo 2nd gear at 650rpm. rear is locked, front was an unlocked ELECTRAC.
    3 days of wheeling burned 5 gallons diesel. the gassers burned 30-40 gallons.
  11. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    Italessi, I've got a 4BT question...see new thread.
  12. mcinfantry
    Dec 2, 2003
    308
    no counterbalance shaft. stock frito lay motor mounts.
    bowetieblazer on here went with me. hes going to put a 4bt in his after riding with me, (and i let him drive). i let tons of people drive at kentucky and converted 4 to cummins 4bt fans.
    it doesnt idle that bad and like i said works with my gears and tires just fine.
  13. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Cory.
    If you're getting your numbers from a tach it needs to be re-calibrated. 3.42's, 33's, TH350 @55 mph you're spinning a hair under 2000 rpm. You're on the edge of roasting that tranny no matter how it's built. I'd run 4.10's at the least with the 35's.
    Rene
  14. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    i already re-calibrated it once, cuz i thought it was off, but its not. So you think i am gonna blow up the tranny? I thought it might drop some rpms if i went to bigger tires?
  15. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    I talked to the guy who built the tranny, and asked him about the gearing in it, and he said he put lower gears in it for the bigger tires. Do you think this is why i am turning a high rpm, with the 33s rite now? Thanks.
  16. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Rene, auto tranny's will always run slightly higher RPM's than the gear calculators say if they dont use a lock up converter. There is an efficiency loss in the torque converter since it can never reach a 100% power transfer with out the lockup device.
  17. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I do know that Kenny. I don't rely on the online gear calcs out there...I do the math and input the numbers based on whether it's a manual tranny app, auto without lock-up or auto with lock up.
    55 x 3.42 x 355 / 33
    If it was a manual tranny or a lock-up auto you multiply by 336 instead of 355.
    Either you don't have 3.42's or your tach is off. The math doesn't lie. At 55 you are spinning 2023 rpm max with 33's.
    Rene
  18. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I ran 38.5 gumbos with 4.10s and it was a major slug. Truck was a '83 1 ton crewcab, NA 6.2 diesel with SM465/NP205. That much tire needs a turbo, IMO.
  19. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    I know the tach is right because there are only 3 calibrater settings, ones for a 4 banger, one is for a 6, and the other is for an v8. So the calibration isnt off, and i am getting the rear end re built on tuesday, and i will ask the guy what gears are in it, but i am 90 percent sure that they are 3:42s, just because the card in the glove box says, and i know my uncle didnt change the gears, but i will find out on tuesday.
  20. kennyw
    Jun 9, 2002
    13,224
    94
    Cool, /forums/images/graemlins/thumb.gif Didnt know how you got your #'s and I didnt have the time to calculate anything myself. Sounds like you were way ahead of me then /forums/images/graemlins/doah.gif
