Gears?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ggallin13, Apr 10, 2000.
  1. ggallin13
    ggallin13 1/2 ton status
    Mar 31, 2000
    199
    Northern Nevada
    How can you tell which gears you have? I looked on the tech page here at ColoradoK5 and it says at the top that the info doesn't apply to Jimmys (I have an '82).
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    The sure fire way to know exactly what you've got is to take off one of your diff covers and count the teeth. Take the number of teeth on the ring gear and divide it by the number of teeth on the pinion gear and thats your gear ratio.
    '73 K5
    Chevy good...Ford bad
  3. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    Well an old method I learned from a farmer was to make a chalk mark on your tire and mark where it is in location to the ground, then count the revolutions of the driveline until you reach that point again. For instance 3 revolutions of the tire would be 3.08 gears. I marked a line on the drive shaft to.
  4. Steve88
    Steve88 1/2 ton status
    526
    Sunny Arizona !
    Not a sure fire way, (since they obviously could have been changed), but if you still have that sticker in your glove-box there is a post here that had the codes for gears (Gxx).
    <font color=red>Steve88</font color=red>[​IMG]
    88K5 Silverado
    thunderdog@metallica.com
  5. CK5
    May 19, 1999
    21,626
    703
    CO
    If your going to pull the cover, the ratio will be stamped on the gear, just rotate untill you can see it. Mine says something like 10 4 1 wich means 4:10 gears. Also the Blazer specs are nearly identicle (did I spell that right) to the Jimmy, I just put that disclaimer there because I got most of the info from a Chevy book.
    Steve
