gears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sammy, Mar 27, 2001.
  1. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    On a 12bolt, what are the gear numbers for 4.56.
    Same with 10bolt front and 10 bolt back.
    my guess is 41 ring, 9 pinion.
    What would be even more perfect will be part nummers and brands. Some $hithead in the Netherlands here, doesn't really get it.
    "K5 Grand GT Blazer Silverado in the Netherlands."
  2. Sammy
    Dec 8, 2000
    250
    nobody?
  3. dyeager535
    26,980
    I've noticed that GM will use different numbers on the ring/pinion to get the same ratio. You are right, 41 and 9=.4.55555555555555 whatever, so thats 4.56. Have you tried summit and jegs?
    Dorian
