gears?
Discussion in 'The Garage' started by bigcountryk5, Apr 18, 2005.
  1. bigcountryk5
    bigcountryk5 1/2 ton status
    Mar 13, 2004
    931
    G-vegas(Greenville) South Carolina
    how do i figure out what kind of gears are in my axle's?
    i figure i have to pull the cover off but what then?
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    1) You can pull the cover off and count the # of teeth on the ring gear and divide that by the # of teeth on the pinion gear. You also get to inspect the diff fluid for metal shavings.
    2) There should be a stamp on the ring gear.
    3) You can leave the diff cover on and put a chalk mark on the driveshaft and a mark on a tire. Have someone drive in a straight line slowly and count the number of times the driveshaft rotates after the tire rotates one time.
  3. bigcountryk5
    Mar 13, 2004
    931
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    The chalk mark on the driveshaft method works, but its sometimes off. Sometimes doing it that way is hard to tell the difference between 3.73's and 4.10's, or 3.42's and 3.73's. The best way to make sure you know exactly what the gear ratio is, is to pull the diff cover. There will be a stamp on the outside edge of the ring gear. There will be a string of numbers. The first one is a long one which is the serial number. Then there will be 4 more. 2 of those are the gear ratio, you divide the two to find the gear ratio. Im going from memory so it might not look exactly like this but it should be something close: (17854623-serial number, then 7 81-this would be the build date july 1981 in this case, then 9 41-this would be 4.56's in this case). It might not look exactly like that (17854623 7 81 9 41), but you get the idea.
    -Harrison
  5. bigcountryk5
    Mar 13, 2004
    931
    thanks again for the help
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    to know 100% pull diff cover and look on outside flat edge of ring gear, it iwll ahve teeth counts of both gears stamped into it, and also gm part number and also date stamping code, divide the teeth counts to get ratio
  7. LittlecountryK15
    LittlecountryK15 Registered Member
    Mar 30, 2005
    28
    Greenville,SC
    we got it off and the only number seen were 6 21 76 DANA E 18520 A3D6 45 11.......I divided 45 11 and got 4.0909091 so does that mean that I have 4:10 gears or am I doing this wrong?
