Gears
Discussion in 'The Garage' started by tbsdontstop, May 27, 2005.
  1. tbsdontstop
    tbsdontstop Registered Member
    Oct 31, 2004
    15
    Michigan
    Whats the easiest way to find out what gear is in my axles?
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Well sometimes you can find info stamped on the axle tube. But thats usually impossable to find, and then you must decode it. You can take off the cover and the ring gear tooth count and pinion tooth count might be stamped on the ring gear. Then you just divide. Or you count the ring gear teeth and the pinion gear teeth then divide. Or you can mark the tire and drive shaft and while in nuetral see how many turns of the driveshaft it takes to spin the tire once. 3 times = 3.07, 3.5 turns = 3.55 gears, 4 turns =4.10, etc... :cool1:
