Gears?
Discussion in 'The Garage' started by BlitzK5, Aug 8, 2005.
  1. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    What gears should I run with a 454 engine without excessive rpm's on the highway since the powerband for these engines is around 2200 - 2600rpm if im correct. I have a TH350 and 37"tires, also a 14 bolt in the back and open a 10 bolt in the front. Im thinking either 4:88 or 4:56? I do however want decent gas milage since there will be alot of highway driving involved. Also are 4:88's to small for a 10 bolt?
  2. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    I'd go with 4.56's for your application. And yes, 4.56's for a 10 bolt front will be stronger.
  3. BlitzK5
    Jul 29, 2005
    288
    Anyone else here have my setup that could offer some advice? Like wishing they had gone with lower gears or higher gears?
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I am about ready to go with that exact same setup. I will be going with 4.88's and 38.5's. I'll never be able to run smaller than a 37" tire again if I want to drive it on the street. But it sure will be fun!
