gears
Discussion in 'The Garage' started by jayccb, Jan 21, 2006.
  1. jayccb
    jayccb Registered Member
    Dec 26, 2003
    18
    wisconsin
    I am running 35s on a 10 bolt with 3.40. The rear end was rebuilt, I would like to run 4.56 according to a chart I read. When changing gears, is that rebuilding the rear end and front end? Will the 10 bolt hold up? Is the th700r a good transmission, will it hold up to abuse and an engine swap down the line?
    thanks
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I run 4.10'sin a 10 and 12 and like them. A 10blt will be fine if you're not too aggressive on the gas. You HAVE to change front and rears together if that's what you're asking. I like my 700 and have just rebuilt and beefed it after 170,000 miles. They're good boxes when not abused so I guess it depends what motor swap you're thinking of. If you're considering ZZ502 or similar I think you'd want to get the box seriously beefed to take it but it will handle a good small block ok. (IMO)
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    700 will hold up ,if you keep it cool, with a mild motor. The OD is nice with those gears and that size tire. I am running 39.5 with 4.56 and a 700.
