gears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by country, Nov 28, 2001.
  1. country
    country Newbie
    Nov 28, 2001
    tx, usa
    is it possibe to instal gears yourself if you have the tool to measure the gaps with or do i need a case spreader as well?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    we have done our own gears here. The only thing we dont have is the pinion depth checker.... So far so good, just mae sure your wear pattern looks good.
    Mike
    <font color=green>"1024x768x256... Sounds like one mean woman."</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I did my own gears. Needed a dial caliper and a backlash indicator. With those tools and checking of the pattern, everything has been fine. Hardest part I found isn't setting up the gears but is crushing the sleeve.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Please fill out your profile so we can tell what type of K5 you are working on.
    I did my own gear swap for the first time last summer and so far so good. No I didn't need a spreader but I did buy a shop press and a few other tools. I took my time and had the job done in 3 weeks, working on it mostly on the weekends and some week nights in my driveway.
    <a target="_blank" href=http://coloradok5.com/gallery/Burt4x4>http://coloradok5.com/gallery/Burt4x4</a>
  5. jbissette
    jbissette 1/2 ton status
    Aug 8, 2001
    101
    Idaho Falls, Idaho
    I have helped with gears in a 1980 chevy 1/2 ton with a 10 bolt front end and 12 bolt rear. Also in a 1988 chevy 1/2 10 bolt rear. It wasn't too bad.
    88 Chevy K1500, 350 TBI, TH700R4, 3" body lift, 33x12.50x15 Tires
  6. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Brian, did you try to precrush the sleeve or did you do it all while in the housing?
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
  7. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    All in the housing. I don't have a press, so I had a shop press on my bearings and such. They wouldn't pre-crush the sleeve for me. I also don't have an impact wrench!
    I had to put everything together, drop the wheels on the ground, put a cheater bar under the ear of the yoke (to keep it from turning), and use 4 feet of cheater to crank on the damn thing. Still tended to wrap the axle and lift the rear of the truck as I would crank on it (didn't have to go to the gym for a few days). Was a real PIA!
    Brian
  8. Leadfoot
    Nov 28, 2000
    3,112
    I here ya! Makes you appreciate air tools when you have them. Well at least you can say you "did it the hard way". I did one a few years back and had to have a buddy help. I had a 2.5 foot cheater but my 180 lbs couldn't get it start, so I had a buddy help (thank God for friends). They work cheap too, just a 30 pack or two of beer [​IMG].
