  1. BAD LUCK 79'
    BAD LUCK 79' 1/2 ton status
    Oct 8, 2001
    130
    Panama city Florida
    ok i'm still undecided on what gears to go with..... som one give me the +/- of 4.10 and 4.56 gears.... thanks
    BAD LUCK is better than no luck at all!!!!
    Is it bad that my truck is older than my wife?
  2. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    what size tires are you running and what do you plan on doing with your rig
    79 Jimmy, 5" lift 35 M/T with a 383 puttin out 400hp and 450lb/ft. 4.11s Locked front and back.
  3. BAD LUCK 79'
    Oct 8, 2001
    130
    Panama city Florida
    Re: ...gears
    my wish list is for 40' tires..... and mostly it's for muddin and good offroadin... never realy got into rock crawlin...
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Re: ...gears
    It would also depend on your motor. For mud, you need a lot of wheel spin. For 40" tires, I would say go with 4.56s. If you go with a higher gear (4.10), you will need a lot more torque from your engine to turn the big wheels in the muck. The higher gears would give you more overall wheel spin, but if your engine can't get'em to move, it wouldn't do any good.
    I have 4.56 with 35" tires and love the setup. I plan to run the same gears when I go up to 38s. I would definitely go 4.56s. If you were rock crawling or something, I would say go as far as 5.13s. But, since you aren't, I would think 4.10 wouldn't be enough gear but 4.56 would set just right.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
