Gears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Z3PR, May 17, 2002.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'm going to use 35" tires. My Blazer has a 400 cid small block, and a TH350 tranny, and fulltime T-case. What would be the best gears for trails ????? I live in small mountins. I still want to be able to go down the highways with the flow of traffic, but don't want my truck to be a pooch off road. What do ya'all recomened for gears ???????
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I need a recomendation
  3. mudrunner78
    mudrunner78 1/2 ton status
    Sep 7, 2001
    366
    Rocksprings, TX
    I ran 4.10s with your combo and really enjoyed them. Jesse
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've got a TPI 383, Turbo 400, 4.10's and 35 inch BFG Muds. I'm pretty happy with how it goes, on road and off. If it had an overdrive, then I think 4.56's would be a better choice.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    The local 4X4 shop is recomending 4:88's with a Detroit locker in the rear. They'll do a package deal of (6" lift with ORD shakle flip and greasable bushings, and all releated parts, the gears Locker and rebuild of axles) "I forgot price quoted, but the pakage deal was alot cheaper then I could buy the components for it on myown."
  6. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    yikes... 4.88s? I dunno about a shop that would recommend gears that low on a rig that WILL see hwy miles. I run 35s (for now!) with 4.56s... but I only went that low because I have OD... 4.88s would be pushing it IMO. One thing to consider is that if you went with 4.10s.. you wouldn't have to replace your stock carrier... if you go 4.56s or higher you would.
    J
  7. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I have 35''s and 4.56's and overdrive. It is as low as I would want to go on road even with overdrive. For you I would go with 4.10's for sure. Weren't you talkin about switching to a 14 bolt? A lot of them come with 4.10's from the factory, so you could actually save some money by just putting the 14 bolt in and just regearing the front (and converting to 8 lug)
  8. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    amen to that...i have 4.88s with an overdrive tranny but im running 39 boggers...so its the appropriate amount of gearing for my setup
    Later
  9. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Since you arent running over drive and i assume you're 400 has some good *Umph* i would go 4.10 unless you plan on going bigger in the future. If you KNOW you are going bigger go with atleast 4.56 now so you dont have to change gearing later
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I plan on some 38's or 39's next year.
  11. topless1tonk5
    topless1tonk5 Registered Member
    Dec 10, 2001
    98
    littleton co.
    gear it deep, i run 5:29's and 33's on my daily driver 4runner and i drive 1 hour on the freeway each way to work. i running 5:13's in my k5 with 38.5's and an 7oora, i would go deeper if they made them for a 14bolt. go as deep with gearing as you will ever think you will need because you will ALWAYS want to go bigger!
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    gear ir for hiway and doubler it for off road
  13. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    yeah, what I was about to say too! Course, doesnt that put a lot more pressure on the spider gear?
  14. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    what exactly does a double do..double your gear ratio or something?
    Bryan-later
  15. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
  16. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ahhh ok..thanx...
  17. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    If you are gonna be running 38's or 39's in the future, DEFINITELY go with 4.56's. IMO 4.56's and 35's ain't really that bad at all, even without an overdrive. I think 4.56's and 35's now is much better than ending up with 39's and 4.11's in the future. You don't have to get a new carrier either because they make the wide ring gear for almost all the applications.
