Gears??
Discussion in 'The Garage' started by MR.4x4, Jul 17, 2002.
  1. MR.4x4
    MR.4x4 Registered Member
    Jul 17, 2002
    66
    Hi, i have a BLAZER 4x4 1975 and im thinking of changing my gears because i have 35x12.50, my gears now are 41/12= 3.41
    Dana 44 (front) & 12 blt (rear)
    I was thinking in the 4.11 wat do you think??
    Wat do i need to change my gears??
    only the Ring&Pinion??
    Thanks for your help.. /forums/images/icons/confused.gif
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    depends on how you plan on using the truck, and if its your trail rig or dailly driver, also what kind of tranny you have. guys who run mud dont mind mild gears because you need alot of wheel spin and rock guys like deep gears so you use as little throttle as possible to stay in control. if you have a overdrive tranny you can offset deaper gears for dailluy driving,but if you only drive it on trials who cares how fast you can go? also you will prolly get tired of 35s and want to go with bigger meats in the future so then you run into problems like running 40s on 4:10 gears (oops i'm doing that) and have to spend the money to regear AGIAN. hope this might help
  3. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    4.56 and 35's work together really well, plus you can get away with38's in the future if you wanted /forums/images/icons/grin.gif
  4. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I run 35's and 4.56's. It's very quick off the line, especially with my worn down 35's.
  5. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    To do the swap your perposing, (if you already know the terms I'm sorry), You will need new carriers, which the ring gear bolts onto and is your actual differental. An install kit, which includes all the bearings, marking compound, shims and bolts. And a gear set, ring and pinion. To do the full swap in a housing that was 3.73:1 I don't think you would need carriers. The carrier in the front you already have maybe usable for 4.11:1s. I'm not sure.
