Gears??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MR.4x4, Jul 17, 2002.
  1. MR.4x4
    MR.4x4 Registered Member
    Jul 17, 2002
    66
    Hi, i have a BLAZER 4x4 1975 and im thinking of changing my gears because i have 35x12.50, my gears now are 41/12= 3.41
    Dana 44 (front) & 12 blt (rear)
    I was thinking in the 4.11 wat do you think??
    Wat do i need to change my gears??
    only the Ring&Pinion??
    Thanks for your help..
  2. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    4.10's would be a good choice if you plan on running 35's for ever.If you plan on running bigger tires later go with 4.56's and only change gears once.Its pretty expensive and a pain in the butt.You will need a ring and pinion for each rear and an install kit which comes with new bearings and shimset...
  3. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Ya, you need a ring & pinion and install kits.
