gears?
Discussion in 'The Garage' started by purple76pearl, Mar 2, 2003.
  1. purple76pearl
    purple76pearl 1/2 ton status
    Jan 13, 2003
    450
    missouri
    i have a dana 44 up front and 12 bolt rear, and i want to go from 3:08 to 4:56 gears, a guy in town told me he coudl get me everything for 356 bucks, is that cheap or high, what all would i need to go to 4:56 gears and what brands should i buy or not buy? /forums/images/graemlins/k5.gif
  2. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    That would be really cheap for new parts. You need the two sets of gears, two install kits, and you're going to need a new carrier for each axle in this case because your going past the carrier break which is 3.73 for the 44 and 3.42 for the 12 I think. Sounds like he gave you the price for parts for one axle.
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Wow....$356 is very inexpensive if that includes everthing.
    A Ring & Pinion goes for about $150-200, an install kit for about $100, and labor for about $100-150 for one diff. Take that amount times two and you've got about $700-800 /forums/images/graemlins/eek.gif. I would check and see what is included for $356. Good Luck! /forums/images/graemlins/thumb.gif
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    3.42 for a 12bolt /forums/images/graemlins/eek.gif that sucks I figured it was 3.73
  5. trouble1
    trouble1 1/2 ton status
    Sep 28, 2002
    346
    travelling, probably lost
    Sounds really cheap...I just spent just shy of 500.00 on 456's and install kit for my 10 bolts...
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    if your old bearings are ok it's not imperative that you get an install kit.
  7. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Well I don't which number you would assign to the break...3.42 and higher is one carrier and 3.73 and lower is another for the 12. Its 3.73 and higher and 3.93 and lower for the 44. Sorry for the confusion.
    You might as well change the bearings while its all apart., IMO.
