Gears?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NAUBlazer, Mar 31, 2003.
  1. NAUBlazer
    NAUBlazer Registered Member
    Dec 3, 2002
    18
    Chandler, AZ
    Hey all,
    I have a couple of questions about getting gears re-done. I have an 81 K5 with a th350. 12 bolt in back 10 in front. I was wondering if 4.10 would be good for 4" lift and 35's. My truck has a hell of a time trying to go between Phoenix and Flagstaff due to the hills. Before I put the lift on a couple years ago it still had trouble up the hills. I was also wondering if anyone knew of a good shop in AZ for get gears redone. Thanks for the info
    --Adam /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    dunno about shops, but 4.10 is a good gear choice for 35s. Its pretty much as low as you can go without OD. I run 35s and 4.56s on-road, but I have a 700r4 (and therefore OD). Anyway, 4.10s should work well for ya,
    j
  3. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    ditto
    /forums/images/graemlins/burb.gif
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Something that you might look into is swapping the axles to a set from a 3/4 ton. You might not need the added strength, but since 3/4 tons came from the factory with 4.10s sometimes you could pick up a set of axles for under $500 and save yourself some money. You will have to factor in the fact that you'll need new 8 lug rims, but you should still come out ahead. Just another option for you. Also, 1/2 tons that came from the factory with 6 cyl engines had 4.10s most of the time. /forums/images/graemlins/thumb.gif</font>
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    DesertDueler (Dan) does gears. He did the gears in my 14bff rear, and also my 10 bolt front. He does good work. PM him. He might get you hook ups on parts too. He is in Chandler also.
  6. NAUBlazer
    Dec 3, 2002
    18
    Chandler, AZ
    Thanks for all of the info guys!!
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Sent you a pm. I can do the gears for you.
    Dan
  8. Panther212
    Panther212 Registered Member
    Jan 4, 2003
    56
    Phoenix, AZ
    PM enroute, I wanna help
