  1. psychoseven_0
    psychoseven_0 Newbie
    Dec 9, 2000
    3
    mo
    i have an 86 blazer with 3.08 gears in it. i am interested in changing them to maybe 4.10 or lower. my question is do you have to change anything in the rearend other than the ring and pinion. i heard if you go too large you have to change the case the gears go in inside the rearend. if anyone can help me that would be great. thanks
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    There is a gear split between series 3 and 4 carriers, but Richmond makes a thicker ring gear for the series 3 at 4.10.... 12 bolt or 10? I'll give you the numbers for my 12 bolt, if that's what you have.
    <font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
  3. Hank75
    Hank75 Registered Member
    Nov 30, 2000
    31
    i am doing the same swap from 3.08 to 4.10, any info would be appreciated. dana 44, 12 bolt. also plan on locker in rear, detroit.
    thanks
  4. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    FWP is right on. You need to have gears for the specific carrier your using. Or you can buy gears that are 4 series made for a 3 series carrier, they are thicker. You could also just get a spacer for the 4 series gears in a 3 series carrier, I do not recommend this because, between the carrier and the gears is another thing to break or get loose. once you aquire the proper gears for the carrier you have, installation is the same...........js
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    The Richmond number for the 3 series case, 4.10 gear set on a GM 12 bolt is 6903501, Have fun...
  6. psychoseven_0
    Dec 9, 2000
    3
    mo
    thanks for trying to help me with my gear question, but i don't know what series carrier i have or how to find out what series i have. is there some way to tell without actually taking the rearend apart? any help is very appreciated!!!
  7. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    You've got the 3 series carrier. The split was from 3.73's to 4.10's. This means that any lower, (numerically higher), gear ratio from 4.10 and up has a series 4 carrier. Higher ratios, (lower numerically), have a 3 series carrier. This is what I can remember. I'm almost positive it's right, but I could be wrong. Someone correct me or back me up.
    HTH,
    Buddy
    I've got my dream truck and it's a 72 K-5 that is getting there!!
  8. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I think that's right- series 3 is 3.42 and lower, If it's a 12 bolt, not sure about 10 bolt split.....
  9. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    same split with the 10 bolt
    Bill Innes
    88' Jimmy
  10. psychoseven_0
    Dec 9, 2000
    3
    mo
    thanks for the help EVERYBODY!!!!
