Gears??
Discussion in 'The Garage' started by nickstegeman, Aug 11, 2003.
  1. nickstegeman
    nickstegeman Registered Member
    Dec 11, 2002
    38
    Dallas, Texas
    I just gort the lift on my 85 rig,and I want to upgrade my tires. Problem is, I am afraid to go to big because I have no idea what kind of gears I have. How can I find out? Is it stamped on th axle or anything???? /forums/images/graemlins/1zhelp.gif
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    If you are lucky, you could still have the factory options sticker on the inside of your glove box door. If memory serves me correctly, that will tell you.
    They are not stamped on the axle, but the ring gear (the big one) is stamped with the teeth count on it. For example, 41 11 on the ring gear would indicate 41 teeth on the ring gear and 11 teeth on the pinion equaling a 3.73 gear ratio.
    Worst case scenario, count the teeth!
  3. nickstegeman
    Dec 11, 2002
    38
    Dallas, Texas
    But is there anyway to check without taking the diff. apart??
  4. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    There IS a code stamped on the axle tube somewhere,but in my experience of 10 or more gm trucks,only 2 could I find the code at all,and it was hardly stamped deep enough to read it in both cases.Its a 3 letter code usually,like TAD or something like that.You may as well pull the cover and count the teeth,or it may have the tooth count stamped on the ring gear--it probably needs fresh gearlube and gasket anyway!!. /forums/images/graemlins/grin.gif
  5. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Thats EXACTLY what I was going to say! /forums/images/graemlins/rotfl.gif
  6. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Hi!
    I just brought home a 87 Suburban, Where can I find the explinations for the codes in the glove compartment?
  7. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    All you have to do is jack up one or both of the rear tires depending on if you have a locker, and put the tranny in nuetral. Then turn one of the wheels exactly one full turn around while noting how many times the driveshaft spins around. If it spins a hair over 4 turns, it is probably 4.11's and so on. Not an excact science but it gets the job done without looking for casting numbers on the rear and gears.
