Gearz
Discussion in 'The Garage' started by k5freak44, Mar 20, 2005.
What ratiooooooooooo
  1. 4.56
    21 vote(s)
    31.8%
  2. 4.88
    22 vote(s)
    33.3%
  3. 5.13
    23 vote(s)
    34.8%
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    Gearz, What ratio and Installation
    Hey guys im currently running 36in iroks and i want to go a little bigger when i get my 14bff in. I am not sure what gear ratio to go to but i want to go low. This truck sees a highway about once every other week and it is my dd. I would say i drive it 15 miles a day just going to school and work. I want to go to around the 37-38.5 range, so what should i gear down to? I will be running a 10 bolt up front.
    Also on a similar subject who all here has done their own gears. I think it is a good oppourtunity to learn while my 14bff is sitting in the garage and i wont be out of a car for any amount of time. I know it is a really detailed install but i dont want to be held at the mercy of 4wp's install fees either. All i have ever done to a diff is drain the fluid and pop off the cover. What do you think i should do?
    Thanks, and im open to all comments.
    Oh and im running a 350 with a 700r4/np241
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I voted 4.88's because I am not really sure how strong the pinion on the 5.13's is for the 10 bolt front. If the pinion isn't subtantially smaller on the 5.13's I would say run 5.13's. If not run 4.88's.
    I have 35's with 4.56's and a 700R4 and I don't like it. It is ok, but not great, especially if you run 36"+ tires.
    Harley
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I love my 4.88's with 35's, I would go 5.13's even if you keep the 36's.
  4. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Where is the 3.73s?
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I'd like to have 4.88s to go with my 40s.
    I think 4.88s are pushing it for pinion size on a 10 bolt. 4.56s are the last of the safe ratios. I think with 5.13s you'd run the risk of spitting teeth off the ring gear with stock shafts. With aftermarket shafts it'll probably eventually happen.
    When it comes to buying new gears though I'll probably just buy 5.13s if they cost the same as 4.88s. It's a wheeling rig so if it breaks I'll just pull it apart and send the gears in to get warranteed. If it was my daily driver I'd be more worried about it.
  6. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    I agree that 4.56 is the largest safe ratio for a 10 bolt. What trans or tase setup do you plan to run in the future? With a 700r4 and a np241(208), known as the poor mans doubler, you could probly get a way with 4.56. I think 4.56 and 35"-37" is the biggest you could get away with on a 10 bolt.
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    i wouldnt pay to swap gears in a 10b personally. if you can do it yourself cool... if not, just bite the bullet and go 60.
    j
  8. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    I agree, 4.56 is max for 10 bolt...safely. 4.88 and 5.13 pinion head is to small.
  9. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I just installed my 5.13s this weekend. I had an experience friend supervise me and I did the work. Its a 10bolt-14 bolt combo. Yes I know that the 10 won't hold up long but I cant find a D60. Anyway the front only cost me $129 for the gears and $30 small install kit. $199 for the 14bolt gears and $99 mast install. Like I said I saved the cost of installation doing it myself. It wasn't that bad just a little time consuming. You'll definately need a press, bearing puller, dial calipers, and a torque wrench. I really like the feel of my 5.13s and 42s. On a different note if your putting a 14bolt in for the first time, the disk brakes are a must. Those things are sweet.
  10. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    Thanks for all the feedback guys. I dont plan to ever get a dana 60 so i think i will go with 4:88s just to be safeR. The drums are already trashed and im looking around for some disks convos.
    I think ill try the install myslef. Thanks
  11. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    ideally 5.13 would be best w/ a 700, but w/ a 10b i guess 4.88. i didnt even know u could get 5.13's for a 10b.
  12. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    yea 513 is the lowest for a 10bfront.
  13. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    what gears do you have now?just wondering if they are still stock running the 36's.i would go 4.88 at most and hope that the 10 bolt doesnt grenade.
  14. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I don't see 4.10 either :dunno:
  15. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    im decided - 5:13
  16. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    With a 36 inch tire, 700r4 and 4.56 gears that will put you at about 1780 rpm in OD and about 2620 rpm in 3rd at 60 mph
    With a 36 inch tire, 700r4 and 4.88 gears that will put you at about 1900 rpm in OD and about 2800 rpm in 3rd at 60 mph
    With a 36 inch tire, 700r4 and 5.13 gears that will put you at about 2000 rpm in OD and about 2950 rpm in 3rd at 60 mph
    These are just some rough estimates to give you an idea what the difference would be.. :thumb:
