Gen 1 or Gen 2???
Discussion in 'The Garage' started by fwdjunky, Jul 20, 2004.
  1. fwdjunky
    fwdjunky 1/2 ton status
    Oct 12, 2003
    499
    Maricopa, AZ
    Ok, so I just picked up an unfinished s-10/K5 hybrid from a friend. What I wanted out of it was engine, tranny and t-cases. That leaves me with a frame, springs, what I believe to be d44 front (flat top knuckles) and rear axles, and an s10 cab. All this will be for sale soon, but what I don't know is the year of the frame. The Guy I bought it from wasn't sure. Is there a definitive way to tell the difference? Oh, and if it is Gen 1, can I still use the rear springs as doners for the front of my truck (52" spring swap) ? Thanks a million guys!
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    The only thing that comes to mind is the engine crossmembers are different between 1st and 2nd Gens. That would be the most noticable i think. Don't ask me to explain what each looks like because its been a while since i've seen a 1st Gen crossmember, but that also doesn't mean that someone hasn't changed it to a 2nd Gen which is common place.
  3. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    You can look for the VIN stamped into the passenger frame rail under about the seat area, maybe a bit forward. Also, are the frame rails straight? If not, then it would be a 78-up second gen frame.
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    front spring set up is a dead giveaway.
    the front hanger is right under the body mount not off set like the 73+. also the spring rear shackle of the front springs have a stop on the drivers side to limit travel. Also spring length. 67-72 the fronts are 47" the 73+ are 49" long. Also the rear shock mounts would be a key hint. pre 73 shocks both faced forward. 73 and later are one pointed forward and one pointed back.
  5. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Also, aren't he springs perches narrower on the Gen 1?
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I can't remember if they were wider or narrower. The 1st gens were the same spacing as the later 1 tons.
  7. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    I'm thinking narrower, by like 1.5" or something like that.
  8. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Spring spacing is the same for all blazers, subs, and trucks on the front.
