GEN 2 DOUBLER
Discussion in 'OffRoad Design' started by RUSS84K5, Jan 24, 2001.
  1. RUSS84K5
    RUSS84K5 1/2 ton status
    Jan 9, 2001
    172
    NEW HAMSHIRE
    Stephen,
    On the Gen 2 doubler adaptor, are bushing mounts leavel with the mounts on the factory 203 adaptor?
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I'd have to measure it closer to make sure, but they're close. I'll see if I can check that out. But keep in mind that if they're the same distance from centerline, any angle on the drivetrain will create a height difference between them compared to the ground or frame. They're built to the same lateral spacing from center as the 203 mounting foot.
    Making the world better, one truck at a time.
    SW-ORD
  3. grumpy
    grumpy 1/2 ton status
    Jan 7, 2001
    353
    San Diego, CA
    Stephen,
    What are the upgrades on the Gen 2 doubler?
    David Giguere
  4. BREAKER
    BREAKER Registered Member
    Jan 9, 2001
    5
    NW Colorado
    Hey Stephen,
    What kinda price tag am i lookin at for the Gen 2 and are you building cross member kits for them?I'll be using a TH350 adapter with a 700.
    JD Taylor
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We've got the pricing and more details on the GEN2 on our website, so you can check that. No crossmember kits at this point.
    SW-ORD
