Gen I or Gen II
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Michk5, Sep 25, 2005.
  1. Michk5
    Michk5 1/2 ton status
    Jul 19, 2002
    139
    Misawa Japan until December...moving to Wichita Ka
    I'm embarrassed to post this but it's a must...
    I'm working the deal out on this doubler right now and it's supposed to be a GEN II, but it looks the same as some of the doublers I've seen posted as GEN I's...
    I must be missing something right??
  2. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    That looks like a Gen I to me....
    IIRC the Gen I is a welded steel unit (which that picture looks like) and the Gen II is the all-aluminum CNC machined "sexy-as-hell" one.
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    #1 Unit Style
  4. Michk5
    Jul 19, 2002
    139
    Thanks Greg
    Anyone else?? PLEASE :confused:
    Matt
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Don't forget when it comes to the steel welded ones, that ORD isn't the only company/person making those.....I'd be insisting that I see a receipt before I shell out any money.
    A welded steel unit would definitely warp during the welding process. I think ORD actually went to the trouble of "surfacing" them after welding to insure that the mounting surfaces were still perfectly flat. Otherwise, you might be fighting leaks forever.....
    Something else to keep in mind.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    That looks like the old style steel version Gen. II Doubler.
    The Gen. I series used stock adaptors between the 203 and 205. Gen. II, both steel and aluminum versions eliminated the stock adaptor between the 203 and 205.
    The Gen. II steel adaptor was taken over by the current aluminum adaptor which is much stronger than the welded up steel adaptor.
    Another thing that "phased out" the Gen. I's were the fact they used stock adaptors between the 203 and 205 was that they added different lengths to the overall length of the assembly. This was either a negative or positive depending on each person and their intended uses. Some Gen. I's would sit the 205 way back further than a stock Gen. II setup. This would make the rear d-shaft shorter and in result, more severe d-shaft angles with more lift.
    Another reason was the fact that there were something like 3 different output shafts made for the Gen. I to fit whatever tranny you had. Reports were breakage of the lower splined units, such as the 27 and 10 spline outputs. 32 spline was the strongest and therefore employed as the only replacement you could get, hence the need for the newly designed adaptor to fit between the 203 and 205.
    I still wish ORD would make the Gen. I setup as I could use the extra length of the whole shebang for a longwheel base truck. This would allow better front shaft angles.
  7. Michk5
    Jul 19, 2002
    139
    Damn--Damn--Damn!! I should of "REALLY" did my homework before I started this. Well on the other hand, my buddy isn't supposed to pick it up for me until this upcoming weekend so no money has changed hands yet :D . However, I'm dead set on having a doubler now and currently looking at North West Fabs. It's a little cheaper than ORD's and I like the design but ORD's GEN II's are proven. Does anyone have any experience with NWF's Doubler??
    Thanks a bunch Greg and Sweetk30
    Matt
  8. Michk5
    Jul 19, 2002
    139
    So I guess the doubler "dallassmith" has is actually the early GEN II also...
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, thats a Gen. II steel version adaptor.
