Gen. IV, V BBC's
Discussion in 'The Garage' started by tiger9297, Jul 28, 2006.
  1. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    When did they become Gen V's?
    I have heard that you should not use a Gen IV head on a Gen V block b/c the water jackets were moved. Is this correct? Is anyone doing this?
  2. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    I don't think they moved, they were just different shaped. My buddy has been running into this problem. I wish I knew more about it.
  3. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    You're right there is a water jacket problem with this combination. Someone makes a conversion head gasket but I can't remember who. :doah:
    I believe '95 was the introduction of the Gen V motor.
  4. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    according to my book on big-block chevy's mkIV went to '90. '91 is when the Gen V was introduced. mark IV block has a 2-pc rear main seal. GenV/GenVI use 1-piece rear main seals.
    I'm not entirely certain but iirc, stock heads can't be interchanged with different type of blocks. (i.e mk IVheads on a GenV block)
    however, there are aftermarket heads that will work with either block - edelbrock and World Products come to mind.
  5. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    1991 was an odd year (as I know, that nvrenuf knows from first hand experience :D). I did some research, and I have found that the Gen-IV and Gen-V where both available in 1991. The Gen-V Big Blocks went into the newer body style C and K series models (actualy it may have only been C series models), while the last of the assembaly line Gen-IV Big Blocks (L19 option code) went into the last of the old square body style R and V series of trucks. I wish I could find a good web site with definitive info on the different Big Block Generations, and their design differences.
  6. tiger9297
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I should have put this in my original post but the casting numbers on my engine are:
    block- 10114182
    heads- 10114156
    www.moretec.com just says 91 & up for both. However, on the head it does say Gen. V.
    The reason I'm asking is that I don't know if these "156" heads are worth a crap or not. I was wondering if some heads off of an older engine would be better. A buddy of mine has a number of heads including one 049. He has two 236s and according to 3 of his manuals they have the exact same specs as the 049s. I don't know why they would make the exact same head w/ different numbers but it appears that way. Anyway, I can buy these pretty cheap IF they are better than the ones I have and will work on my block.
  7. tiger9297
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I'm still relatively new at this but if the water jackets on the heads are in a different place than the ones on the block how does the gasket solve that problem?
