gen2dblr
Discussion in 'OffRoad Design' started by **DONOTDELETE**, Mar 19, 2001.
    I have a NP205 out of a '88 1-ton Chevy. It has a round bolt pattern, and (I assume) a long 32 spline input shaft. You mentioned that a round bolt pattern was not a problem with your gen2dblr. My question is if the input gear can be swapped for a short 32 spline shaft, like it is done with the 350 version NP205. I assume that I would not have to machine the case to do this, right? Wouldn't it be chaper to swap input gears rather than buy a different NP205 version? I appreciate and information you can give me.
    Thanks!
  1. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We can work with the round pattern, but you will have to swap in the short input gear. It is a direct swap, no bore, no new bearing. At that point, you're ready to go.
    Making the world better, one truck at a time.
    SW-ORD
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    How about selling me this NP205 case?
