General Cooling tech q
Discussion in 'The Garage' started by SchnorrCS, Oct 23, 2006.
  1. SchnorrCS
    SchnorrCS 1/2 ton status
    Oct 11, 2005
    368
    Loveland, CO
    Hey guys...
    Ok here's the word. 74 K5, 350/350. Just moved from Cali to Colorado, and it's cold out right now! My truck won't warm up!? I'll let it idle for awhile, get in and start driving. The temp gauge works, but usually it runs right around the first tick mark. Now it's like a quarter of the way there. What gives?
    Don't know if it matters or not, but I don't run a fan shroud....
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Have you got a 'stat in there? I doubt you really needed one in Kalifornia but you will in colder climes! Pull the stat housing and make sure there is one there and that it is closed when cold.
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    T-Stat stuck open perhaps?
    The fan shroud is going to help cool more efficiently during hot temperatures, as it will pull more air through the radiator.
  4. bandit4369
    bandit4369 Registered Member
    Mar 20, 2006
    82
    Nw. Pa.
    Besides the t-stat, if you have a fan clutch / electric fan make sure it's releasing / cutting off and not driving the fan all the time.
  5. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Is the heater working alright? On my temp gauge that is normal for my truck mabey just above the first tick, it gets to halfway and I start to think its over heating. If the heater isn't working well put a 195 degree thermostat in it. If the heater is working well don't worry about it.
  6. SchnorrCS
    Oct 11, 2005
    368
    Loveland, CO
    That's kinda what I came up with. Tstat stuck open. It has one of the failsafes (sworn to stick open if it sticks) and is 180 if I remember correctly.
    I went and got a 195 (stock) today and will put it in tomorrow. Fan works, it's a direct drive. Putting a clutch on it or going elec would probably help though. If this doesn't cure it (Fluching rad and replacing tstat) I'll go the high tech route and throw some cardboard in front of the rad.
    Thanks guys.:bow:
