general offroad question
Discussion in 'The Garage' started by 85 Jimmy, Oct 7, 2006.
  1. 85 Jimmy
    85 Jimmy Sheepdog Premium Member
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    i'm just wondering what gear you guy's get in when you go offroading
    i've always put it in 4hi for the little trails around here and if i see something that might be interesting then i'll put it in 4lo
    but this past weekend i was out with a bunch of heep guys and they said it's best to always keep it in 4lo because you have better manuverability
    just wanted to know ya'lls opinion on this
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I usually run around the trails in 2lo because of the front locker, then throw it in 4lo when i need all 4 wheels, and 4lolo when my weak ass motor cant move the big pig.
  3. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    4-hi for anything that is fast enough for it to shift out of 1st when in 4-lo.
    Mud, definitely 4-hi for the wheel speed.
    Rocks, 4-lo for throttle control
    access roads and main trails, 4-hi
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I stay in 2hi until I need more. Usually that means I need 4lo to climb.
  5. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    2 hi all the time, unless i need 4wd and then pick the correct range...
  6. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    keep it in 2wd until needed then 4hi. 4lo is for when you are starting to get into trouble, or if you whant the extra control afforded by the lower gearing.
  7. Myke
    Myke Registered Member
    Sep 3, 2006
    31
    New Jersey
    I keep my truch in 2HI until I need 4wd. Then depending if I need the low gears or want to engine brake a lot I'll go in 4low.
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    X2:D
    Ira
  9. JohnDeere
    JohnDeere 1/2 ton status
    Jan 17, 2006
    342
    Houston, Texas
    In my k5 2hi unlit i need 4wd and 4hi take care of pretty much all i do and 4lo for the realy hard stuff. But in My heep on the other hand with that ****y 4 banger it 4lo the hole time.:(
  10. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I use 2 hi most of the time. If I start getting to much wheel spin I use 4 hi. The only time I use 4 low is if I need the gear reduction for crawling out of or over something.
    I do have a 465 though so in high I have all the low range I need in most of the time.
