General Winch Q's & New MileMarker 8000# electric winch (changed)
Discussion in 'The Garage' started by TrcksR4ME, Oct 23, 2002.
  1. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    General Winch Q\'s & New MileMarker 8000# electric winch (changed)
    I am thinking about maybe getting a winch, and have heard to go as big as you can afford. Well I can't afford much at this point, but would still like to have something. There are a few inexpensive winches out there like the Ramsey REP 8000, &8000E, the new Mile Marker 8000# electric, probably some others too. Anyone have any experiences with these winches? Any recommendations, insight, things I should know, etc.?
    The new MileMarker one is selling for $399...which is pretty damn cheap. I cannot find any info on how many HP it is, probably not much. I am guessing these are weak, slow, and....?
    Lemme know what you know /forums/images/graemlins/1zhelp.gif, thanks!
  2. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Re: New MileMarker 8000# electric winch
    anyone...anyone /forums/images/graemlins/1zhelp.gif
    I know you guys have an opinion, everybody here does /forums/images/graemlins/grin.gif
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    They have a warrenty? go for it.
  4. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    we are not very talkive today... /forums/images/graemlins/tongue.gif
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Re: General Winch Q\'s & New MileMarker 8000# electric winch (changed)
    Save your money, get a good winch when you can afford it. IMHO a winch may save your a$$, don't skimp on a cheap one, and have it break when you need it most.......
  6. dubl_t
    dubl_t 1/2 ton status
    Jun 8, 2002
    141
    Oregon
    Buy one, run it through a kwik test, if you like it, buy another one for the back. if not, return the POS for a refund /forums/images/graemlins/grin.gif
  7. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    WARN BABY! SAVED MY A$$ FROM ROLLIN ONCE, I WOULDN'T WANT A CHEAPEE IN THAT SITUATION /forums/images/graemlins/thumb.gif
  8. MJB774X
    Sep 26, 2002
    574
    SO CAL
    you have 8lug 44 w/ 15" wheels, what back space do you have? did you grind your calipers too? cut the backing plates?
  9. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    I think Ramsey makes a great winch, I have a 12K Ramsey. Mile Marker is a good company also. I also own a Warn 9500 and a 8274 (8000K). Either the Ramsy or the Mile marker 8K are OK for a K5. Yes, my opinion is bigger is better as far as winches go BUT - I would rather have an 8k Milemarker or Ramsey when I needed a winch than $400 dollars in the bank.
    The Ramsey business began in 1944, started making PTO winches in the 50's and started making electrics in the 70's. They know how to make good winches.
    Mile Marker started in the 80's with part time kits for full time TC's. Mile Markers are mostly known for their hydralic winches which they supply for the military Hummers also. I have never owned a Mile Marker but I suspect they make a pretty good winch, from reading about them.
  10. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I have 4.25" b.s. I had to grind the calipers and backing plates a little to fit the rims. It is not a safety compromise IMO, there is a lot of metal there. You basically have to slide a rim on, spin it, see where it hits and grind. Paint over the area, put the rim on again, spin, and grind where it hits and so on. It is tedious, but not that bad. First side takes the longest to do.
    The area that needed the most grinding was the edge of the calipers where the backing plates touch. These seemed to be the high spots. You can kinda tell by eye-balling it that it is not perfectly round like the rim is.
  11. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I think I have found a solution. Found a used Warn Winch for sale in my area for $400. Not sure which one, just know its a 8000#, not the upright one though.
