Genius or stupidity?
Discussion in 'The Lounge' started by Chevy305, May 2, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
  2. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i like the duck tape and hose clamps on the intake tube:haha:
  4. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Me and a friend wanted to try that about 15 years ago, but We wanted to use a small turbo off of one of the old Honda Interceptor bikes they had back in the 80's.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    excellent idea, except one thing. durability is a major problem. something about no oil in the turbo. :screwy:
  6. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Can I mow the yard faster???
  7. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    build a small resiviour to mount above the turbo so it gets gravity fed oil. I don't know much about turbos, at least the oiling part.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    need a way to pump it back to the top without being excessively heavy, after all, we're only probably dealing with about 4hp here
  9. Corey 78K5
    13,055
    Humboldt County, CA
    The best way to make a 5 hp Briggs engine make some real power is to use an IC block with cast sleeve and roller crank bearings. Then bore it .10 over and use a Cal Kart billet stroker crank and a cam and lifter kit. A Tilotson carb with a UNI filter, 3 stage header pipe, aftermarket ignition, ported intake and exhaust ports, aftermarket larger valves and springs will result in a 20-23 hp engine that will smoke the tires on a kart.
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    hmmm... my buddy lives a mile down the road, and i drive there quite often. thought about picking up a cheap moped to save on gas. maybe a mini-chopper with one of these on it would be cool. :D
  11. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    mmmkay, I think Corey needs to spend more time with his K5...:p:
    Rene
  12. Corey 78K5
    13,055
    Humboldt County, CA
    Back when I was younger I used to help a friend build his engines for his race kart it was pretty cool what they could do.
  13. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Genius until the head pops off and hits the guy standing over it.... Then, not so genius.
  14. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I really don't think there is enough air flow to get the turbo spooled up fast enough for any real power gains, yeah sure it spins now, but if you listen to it carefully, you really don't hear the whine a turbo usually puts out...
    interesting idea, but would probably be better with a smaller turbo unit, and then i'd like to see the comparison of power ratings with and without...
  15. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    Might have a new project for my buddys minibike :D It already does about 45, i bet it could use some more power. Seems pretty cool tho.
